can 99 lude fit 225's?
Old Mar 2, 2009 | 06:57 AM
bigred!'s Avatar
Default can 99 lude fit 225's?
i have 215's on my car but i was wondering if 225's will fit
Old Mar 2, 2009 | 07:14 AM
carnot's Avatar
Default Re: can 99 lude fit 225's?
Need more info about wheel size and suspension mods.....I see that you are starting all these new threads about topics that have been covered in the past
https://honda-tech.com/search.php?do=process
Search first, most of your answers are here
Old Mar 2, 2009 | 07:19 AM
117's Avatar
117
Given the right offset wheel, yes. You'll likely have to trim the mounting tab on the rear bumper.
I've seen 235/40/17s used with good results on 17x8 +48mm wheels. Require trimming of that rear tab.
I run 225/50/15 race tires on my track car on 15x7 and 15x8 +40mm wheels without any rubbing at all, but the rear fenders required rolling and trimming of that mounting tab. The 225 race tires I use run REALLY wide. Section width is just over 10" on an 8" wide wheel!
Old Mar 2, 2009 | 07:22 AM
98vtec's Avatar
moderator emeritus
+42 16x7.5 wheels
225/45/16 KDW2
TEIN HA's with a functional drop and i only rub the front when the dampers are extremely compressed
Old Mar 2, 2009 | 11:16 AM
lude_lover's Avatar
Im running 225/45/16 on stock suspension and no major rubbing. The only rubbing i have had it due to my stock suspension being 160k old and when I bottom out(doesnt happen regularly) itll slightly rub my fender liner
Volcom
20
Nov 10, 2002 06:48 PM
N24RE
Nov 8, 2002 10:41 AM
Batoutahell
Oct 30, 2002 05:38 AM
Tommy_Gunns
Sep 11, 2002 09:49 AM
bhcvc
May 24, 2002 01:16 AM
