prelude tras bad or whats wrong
Old Mar 2, 2009 | 03:53 AM
v8killaz's Avatar
Default prelude tras bad or whats wrong
so i bough this car and cracked trans cover changed it and now the car runs fine but as it shifts from 1-2 gear it slips , or rpm goes way high and then catches gear.
its an auto NOT A STICK
im thinking its the solenoid, the trans had almost no fluid in it and i just filled it
all other gears are fine
what can this be, i know the autos suck real bad
98 prelude auto h22a4
Old Mar 2, 2009 | 07:12 PM
v8killaz's Avatar
Default Re: prelude tras bad or whats wrong
no help just say a work
Old Mar 2, 2009 | 07:45 PM
TurboHatchB16's Avatar
do what now? i dont understand what he said.
Old Mar 2, 2009 | 08:09 PM
ArmaanOG's Avatar
the t/c might be shot, change the fluid?
Old Mar 2, 2009 | 09:41 PM
on these tranny's once to t/c goes the whole thing most likely does. it send all kinds of **** into the tranny an fries the clutch packs and bearings.
Old Mar 3, 2009 | 09:53 AM
ArmaanOG's Avatar
not true my boys old accord auto his t/c was going and 1st 2nd and 3rd sounding like it was riding the clutch pack and it was deffslipping but was still working
Old Mar 3, 2009 | 07:30 PM
ALIKZANBRO's Avatar
i got the same problem, i was checking it and it seems that the first gear or clutch whatever is damaged because if i put the car in second gear everything is fine. also the oil is almost black i will change it and ill see if that helps.
Old Mar 3, 2009 | 07:31 PM
ALIKZANBRO's Avatar
does your make the same thing on second? let me know
Old Mar 7, 2009 | 10:48 AM
v8killaz's Avatar
no only fiest gear
it was ran with very low fluid before i got it
should i rebuild or swap a 5speed in
Old Mar 7, 2009 | 03:09 PM
ArmaanOG's Avatar
swap a 5 speeds
Old Mar 7, 2009 | 03:18 PM
Kronn 98SH's Avatar
no only fiest gear
Neither. Sell it and use the money to buy a 5spd. That should save you a couple thousand dollars.
Old Mar 7, 2009 | 08:36 PM
v8killaz's Avatar
well i can buy a 5speed swap and everything i need for 600
and of course i install it myself, dont it in a integra
pretty easy just takes tons of time and effort
Old Mar 7, 2009 | 10:07 PM
Kronn 98SH's Avatar
I guess it comes down to how much you value your time.
Old Mar 8, 2009 | 07:08 AM
mattsnooz's Avatar
yup, 5 speed swap and a new ecu. Unless you can solder your auto ecu to convert it to stick (if thats possible for your ecu. I know it is in mine (po6, as it is converted to run manual)
Tranny swap isn't hard at all. I would say installing the shifter cables is the most work out of all of it and getting them adjusted/set properly. Removing the bell housing and shafts isn't too hard. Lots of great write ups in here for easier ways to remove the shafts :D
Goochmoney
Jun 24, 2006 05:31 PM
1990AccordEX
Jan 8, 2006 05:57 AM
toyH22
Oct 20, 2005 11:25 PM
2000prelude
Jun 27, 2005 05:35 AM
DrZaius
Apr 24, 2005 06:53 PM
