Need help w/ swap!!!
i have a 91 EF SI Hatch, i recently purchased a ITR long block from a buddy. it is missing injectors, dizzy, ecu, harness, and i am not sure what i need and which way to go? will i need OBD0 parts or OBD1?? THANKS!!!!
first off i love ur avatar, second if you want to make ur B18 work your going to need a lot of stuff since you didnt get a complete swap and since you already have the motor out like that i take oil pan off and ck over your bearings and such before i went any further alot of times when you buy a longblock like that there is problems with it esp a ITR motor like that thereup ther in the ranks of swaps and more then likely there is a good reason you didnt get everything you need and those motors are notorious for spinning bearings and it is worth it to check it over before you get into buying the long list of what your gona need i would go with OBD2 setup as far electronics but your gona have to custom make a little wiring being the car didnt come with any wiring you need and ITR didnt come until 96 and after. again ck your bottom end before you go investing time and money into everything else that your gona need but if you do get it all and you get it running youll have a mustang eater that you'll enjoy ALOT. nice swap when done correctly real nice good luck and hope you enjoy!
Last edited by HatchbackFreakEK; Mar 2, 2009 at 05:32 AM. Reason: spelling sorry i was in a hurry!
hey thanks for the info. yea i bought it off a buddy of mine who wrecked his ride. it was running really strong before the accident, so i know for sure that everything internally is good. thanks again...
