Which head gasket IE manufacturer
I am building up a 84.5mm LSV and want to know which head gasket you fellas have run and have good luck with. I already have a Vtec conversion kit, just need the head gasket.
I know GE makes one but isn't it just a GSR modified gasket? Will that be a problem with all of the jackets lining up to the block? Can I use stock dowel pins or do i have to buy theirs?
Then there is Cosmetic. Do they make one from scratch? Will the jackets line up better? What about the dowel pins?
Have you guy had any problems witht the above gaskets and which do you think I should use? Are there any other good ones out there?
new_climber
Honda Civic (2001 - 2005)
Aug 28, 2023 12:11 PM
