obd-2 Crank Postion Sensor, 1 or 2 sensors ?
Old Mar 1, 2009 | 08:20 PM
street_ride14's Avatar
Icon2 obd-2 Crank Postion Sensor, 1 or 2 sensors ?
So I've seen these sensors on 5th gen ludes mounted on the exterior side of oil pump and I thought they always had 2 input sensors. Is this true ? .. Do any 'ludes have 1 input sensor at that location ?
Old Mar 2, 2009 | 03:42 AM
98vtec's Avatar
moderator emeritus
Default Re: obd-2 Crank Postion Sensor, 1 or 2 sensors ?
OBD2 USDM h22's have the CKP and TDC sensor located on the oil pump housing
Old Mar 2, 2009 | 04:33 AM
How about the OBD2 JDM h22's ?
Old Mar 2, 2009 | 04:49 AM
98vtec's Avatar
moderator emeritus
the info i have collected says they are all located in the distributor.
Old Mar 2, 2009 | 08:15 AM
This is the item in question. It's from a Prelude, but which year(s) ?
Old Mar 2, 2009 | 08:29 AM
98vtec's Avatar
moderator emeritus
ive never seen that before, but that is the CKP sensor minus the TDC sensor. Originally when i saw that i thought maybe the TDC sensor had been removed for some reason but the connector is only two pins so that kinda eliminates that thought. Maybe from the JDM "OBD2" 96 models. The red headed preludes
Old Mar 2, 2009 | 09:17 AM
A Blue Lude's Avatar
Not a Civic/Integra CKF perhaps?
OBD2 directives required sensing misfires, so you got CKP/TDC both on the crankshaft for OBD2 US Preludes.
Where those directives didn't apply (everywhere else) they were kept in the distributor with CYP.
akinas-crx
Oct 28, 2011 06:00 PM
tdbhonda
12
Mar 20, 2009 07:19 PM
jjmcmana
Nov 1, 2008 09:02 AM
swaplighter
May 31, 2004 03:49 AM
dohcsideSi
Mar 10, 2002 06:18 AM
