Help if you can!!!! 92-95 civic
Old Mar 1, 2009 | 03:45 PM
401RIguy's Avatar
Default Help if you can!!!! 92-95 civic
What kinda Cluster would fit in there without using any fitments or dont have to do no Mods to it? like using Integra Cluster or 99 civic SI cluster?
Old Mar 1, 2009 | 04:01 PM
en00be's Avatar
Default Re: Help if you can!!!! 92-95 civic
do a B swap
its worth it
Old Mar 1, 2009 | 04:11 PM
401RIguy's Avatar
yea i was thinking bout Doing a HTB? but then im jus working on whats in the Car right now! as of now i have a Bseries on the Side going thru a Mild Build with High comp Piston and rods and so on
Old Mar 1, 2009 | 04:15 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Boost it.
Old Mar 1, 2009 | 04:17 PM
401RIguy's Avatar
i was thinking about Spraying on the Z6 motor just for Fun
Old Mar 1, 2009 | 04:18 PM
b16racereg6's Avatar
buy my intake and tb u will like that alot....
Old Mar 1, 2009 | 04:23 PM
EFinawesomeman's Avatar
B16 is straight drop in if you buy a swap from HMO.
Old Mar 1, 2009 | 04:43 PM
401RIguy's Avatar
Not much of a B16 Fan!
Old Mar 1, 2009 | 04:50 PM
6footmidget's Avatar
best build for a d16 is BOOOOOOOOOOSTTTTTTTTTTTTTTT
Old Mar 1, 2009 | 05:42 PM
401RIguy's Avatar
Yes Sounds like a good idea! but then prolly imma end up Spraying this Motor tho!
Old Mar 2, 2009 | 04:53 AM
401RIguy's Avatar
Bump
Old Mar 2, 2009 | 05:23 AM
slo_hatch's Avatar
do you wanna know what type of cluster its in the car?? if so...only 92-95 civic clusters will fit. you can get the ex, si, jdm eg6 cluster...or any of the others. thats all that will fit direct plug and play.
Old Mar 2, 2009 | 05:26 AM
401RIguy's Avatar
bump
Old Mar 2, 2009 | 05:28 AM
401RIguy's Avatar
i know whats cluster i have but then what im trying to say is that will any other cluster fit cause i see other people using like 99 SI and Gsr Cluster in their Hatch so thats why i ask?
Old Mar 2, 2009 | 05:42 AM
slo_hatch's Avatar
no...you have to rewire a bunch of stuff. none will plug-and-play
darrinirox
Oct 17, 2012 06:06 AM
EJ1freak911
13
Nov 4, 2008 01:36 PM
simplemanseven
Dec 27, 2007 02:17 PM
wfocrx
Apr 23, 2007 08:19 AM
PSU
Apr 8, 2002 05:48 PM
