Mid-Atlantic (Sales) VA, DC, and MD
FS: bseries-itr cams-valve cover-TB-GSR blox IM-mounts-axles-Apexi WS-ECU-shift link
Old Mar 1, 2009 | 02:22 PM
jmm96gsr's Avatar
Default FS: bseries-itr cams-valve cover-TB-GSR blox IM-mounts-axles-Apexi WS-ECU-shift link
All items are OBO, please make fair offers – do not waste my time or yours with lowball offers. Items are located near Carlisle, PA 17013. I can meet within a reasonable distance for larger items, or I am Payapl Verified. I can post pics of all items, or I can email them – please ask if there is something you want a picture of if it’s not posted. Please keep negative comments to yourself. I will be adding misc. items later this week.
AEM cam gears – B series: SOLD
’98 JDM ITR cams: SOLD
OBD 2 GSR alternator: SOLD
OBD 2 alternator (I think it’s from a civic) PN# 101211-9330: $50 plus shipping
OBD 2 GSR starter: SOLD
B series OEM plug wires w/ about 4,000 miles: $20 plus shipping
(2) GSR crank pulleys (one has a chip out of it): $20 plus shipping (unchipped), $15 plus shipping (chipped)
SRD light weight crank pulley (B series): SOLD
GSR flywheel (resurfaced about 4,000 miles ago): $40 plus shipping
GSR Blox Intake Manifold: SOLD
68mm Pro Products throttle body (b series): SOLD
Ebay 4-1 stainless header 2.5 outlet (B series): $50 plus shipping
Ebay cast turbo manifold (B series): $50 plus shipping
OBD 2 GSR evap/ purge control: SOLD
Apexi WS catback (PN: 116 KH01 – was on 93 civic coupe): SOLD
B series mounts: SOLD
B series shift linkage w/ urethane bushings: SOLD
B series axles (left & right): $100 for set plus shipping
B series intermediate shaft: SOLD
OBD 1 P06 ECU: SOLD
Chip Burner: SOLD
Sunpro Tach: $20 plus shipping
(2) 4 wire O2 sensors: $30 each plus shipping
Buddy Club Fan switch: SOLD
GSR Hydro shift fork set: $50 plus shipping
GSR power steering pump: $20 plus shipping
Hayame Hood pin set (new): $10 plus shipping
GSR fuel rail: SOLD
B series timing belt cover set: SOLD
OBD 2 GSR injectors: SOLD
5Zigen lowering springs 92-00 civic: SOLD
GSR valve cover (w/ welded bungs for breather setup and cam gear cutout): SOLD
Old Mar 1, 2009 | 04:48 PM
94eg5squadMD's Avatar
Default Re: FS: bseries-itr cams-valve cover-TB-GSR blox IM-mounts-axles-Apexi WS-ECU-shift l
got any better pics? and dents or cracks?
you got the urethane bushing for the shift linkage? the one thats by the shifter?
Old Mar 1, 2009 | 05:09 PM
jmm96gsr's Avatar
I will take a closer pic of the bottom. It has scratches on the bottom - not really a dent, and no cracks. The shift linkage has the urethane bushings @ the shifter end and the tranny end - it's the energy suspension kit.
Old Mar 1, 2009 | 07:06 PM
will you part out just the shifter end of the bushing. ill give you a couple bucks and the stock one.
55$ for header n bushing prolly pick up
Old Mar 2, 2009 | 04:09 AM
jmm96gsr's Avatar
I'm not parting out the bushings. Let me know if you want the header.
Old Mar 3, 2009 | 04:21 PM
jmm96gsr's Avatar
Bump for items sold.
Old Mar 3, 2009 | 06:11 PM
jmm96gsr's Avatar
Sunpro tach. It has a small shift light - right beside the zero.
Old Mar 3, 2009 | 06:29 PM
stince's Avatar
Bump for Awesome seller.
Buy with confidence!
I just picked up that WS exhaust.
Seller is easy to work with
Thanks man
Old Mar 3, 2009 | 08:36 PM
wupike21's Avatar
Thanks again, Joe
Old Mar 4, 2009 | 07:50 AM
jmm96gsr's Avatar
Flywheel pic
Old Mar 4, 2009 | 07:51 AM
jmm96gsr's Avatar
Thanks man
No problem. Thank You.
jmm96gsr's Avatar
Originally Posted by wupike21
Thanks again, Joe
It was nice meeting you, GL with your build.
Old Mar 5, 2009 | 03:31 PM
jmm96gsr's Avatar
bump
Old Mar 7, 2009 | 03:24 AM
jmm96gsr's Avatar
BUMP cams & gears sold
Old Mar 7, 2009 | 07:01 PM
DuongBros.'s Avatar
any cracks in the header?
Old Mar 8, 2009 | 04:19 AM
jmm96gsr's Avatar
no
Old Mar 17, 2009 | 04:31 AM
jmm96gsr's Avatar
BUMP. A few parts still available.
Old Mar 17, 2009 | 06:40 PM
jmm96gsr's Avatar
bump
Old Mar 18, 2009 | 07:03 AM
wolfenr1984's Avatar
I want the flywheel. Pm me with weight. Thanks
Old Mar 18, 2009 | 07:18 AM
jmm96gsr's Avatar
It's a stock GSR flywheel.
Old Mar 18, 2009 | 08:55 AM
What's the current weight of the flywheel?
Old Mar 18, 2009 | 10:16 AM
may I get some better pics of the flywheel? bump!
Old Mar 19, 2009 | 12:26 PM
jmm96gsr's Avatar
bump for item sold
SLIM NOTHING
Nov 29, 2011 03:07 AM
Mr. EG
Apr 29, 2011 05:25 PM
wkuch27
Jun 4, 2009 08:36 AM
