obd1 crx IAT
Old Mar 1, 2009 | 11:38 AM
tallkan's Avatar
Default obd1 crx IAT
any 1 kno or have pix off IAT sensor wiring for obd1 i keep throwing cel10 changed the sensor switched the wires around and still same ****. i believe the wire color is red/yellow & green/white if somebody could tell me which wire goes to which ecu pin immma run wires straight from the ecu. im not to great at reading wiring schematics im all confused any kind of info would help.
Old Mar 1, 2009 | 11:42 AM
93formula's Avatar
Default Re: obd1 crx IAT
if its wired wrong you will keep frying the iat, theres a ecu pinout in the faq i think.
Old Mar 1, 2009 | 12:00 PM
tallkan's Avatar
yea i kno that. i got the ecu pin-out but i need to kno which i is ground and signal. ckuzz the pin-out just say c7 IAT and i think its a diff color wire. like i said i suck giraffe nuts when it come to reading wiring diagrams thats the only reason im lost. thankz tho
wickedEFguy
May 20, 2020 03:51 PM
Zack Gunther
May 17, 2013 07:53 AM
lakahang
Apr 9, 2012 07:14 PM
