Apexi Super AFC NEP or Hondata reflash.?
Hey i got a 06 type S with just a AEM short ram and my future mods will include and limited to just a
shorty header and maybe a high flow cat
and cat-back exhuast
torqe damper
motor mounts.
walbro 255lph fuel pump
Hondata heatshield gasket
lighten fly wheel upgraded clutch
so for just a slight ecu mod for those simple bolt on which is best
APEXI SAFC NEO or Hondata ReFlash?
torqe damper
motor mounts.
torqe damper
motor mounts.
torqe damper
motor mounts.
what is it with ppl never reading up on stuff lol... Hondata reflash or save and get the KPRO... no other ecu mod is better then Hondata! Also most others don't even work for Ks!!!
not true. even in the book for the afc neo thing it has a section for the k20a3. some turned theyy car with one on a dyno and got 9 whp from one and he also had a wide band. he was on a budget but its is too compatible
really, afc 9whp. thats not bad. since i can get it off my friend for free.
Buttt, i just wanted to add about the reflash.. Yes everyone prefer Kpro. But ill give you my 2 cents.. One of my friend had a reflash before going Kpro later with built k24. Started out with the reflash cause there more affordable and easier to come by. Dont sleep on that. not sure which type but it made a huge difference with just i/h/exhaust. he ran 13.9's all day on the track as opposed to what? 14.5.
and later if you want to get kpro you can use that ECU caused its been chipped. not sure if i used the corrrect term.
also buy my rear camber kti if you need it. Postd in the forsale section. haha
It's easy to say save and get Kpro...but for someone who is doing a light build just to make the car a little more fun to drive this isn't a very sensible decision... The reflash would be your best option in this situation as long as you really plan to stop with those mods and you realize what your budget and goals are.
yeah man if its free go for it just dont burn a hole there ur piston running it way to lean lol jk. i dont understand why eveyone says afc wont work on k series they dont seach it up enough to know. no doubt tho kpro is ****ing awesome if you turboing the bitch. lol but good luck man with whatever you do make her run like a champ
yeah i had my 500+ awhp with a STI and a EVO so iam just being senible and do light none turbo work. longer life for everything and still good MPG....lol seriously tho.
is it all possible to do a hondata reflash and use a AFC to for minor tweaks..... say for the header and a high flow cat. i eventually want to do cams can the afc with a reflash handle it. and your right tyte-S k-pro is great iam sure but just for minor gains it's not good for the cost to mod gain.
Either way you will be wasting your time as for the AFC you really need to either 1 no what you are doing or 2 have it tuned on a dyno!
Anyways this subject has been covered a million times and some don't understand that AFC wasn't designed to work with the Kseries! Honda changed everything around when they built the K... The Bs and the Ds where similar in design... I don't know how much you guys want to stress about it but I have never seen someone gain any power with the AFC!
Do you know how long it took Hondata to figure out how the Kseries ECU worked??? Do you know how long it took them to just get the reflash and KPRO out??? Long enough!!! Why do you think the AFC was never popular for our cars??? Its because they weren't made to run with our cars... there was not r&d put into it! Why do you think ppl use either a reflash or KPRO???
You guys clain 9whp gains... where are the charts to proove it???
KPRO is not only for turbo... most use KPRO and are N/A!
ok well i mess be going crazy becuase this guy did it.
http://www.importtuner.com/tech/powe.../photo_08.html
wow math is really not for you!!!!! You guys were saying that ppl were gaining 9whp... I went to go check and he only gained 5 whp! Pretty pathetic when your intake and exhaust did most of that 14 whp gain!
I still wudnt get it free or not. I dont think it will respond as well as the reflash or kpro!! Hondata has r&d behind there product which makes think they know what they arr doing. Especially since it so widely known and used!!
nahh nahh, i was joking bout the apexi neo, I wouldnt waste my time. I dont fawk with wiring and i'll have to pay some rip off shop even with discount to get it installed and tune. But it does look nice
For that much spent, ending up spending the same amount of gettin reflash. Money is soo tight this past few months, I could care less bout hooking up my rsex. unless im econimcally benifitting while buyin crap, like I could have gotten my hands on reflash round my way for $350.
I/RH/E is basically going to be his set up. Might as well scrap the fuel pump too. Not going to really do you ant good with your set up. With what you said you have planned, budget wise, I would get the Reflash, if pockets are deep, there is no reason not to go with the Kpro.
