Hood for LSVTEC in CRX
Old Mar 1, 2009 | 10:09 AM
B16Drag's Avatar
Default Hood for LSVTEC in CRX
I'm sure this stupid topic has been covered before but I can't seem to "nail" down an answer.
I have an LS/VTEC with Hasport motor mounts in a CRX, which CRX hood would fit? It is the USDM version. I've heard the VIS SiR hood will fit, but then I've also heard the ZC one will fit also... But what about the Seibon hood?
Please dont make suggestions like cut your hood skeleton and put washers between the bolts, etc... because I've already done that and want a "smoother" better fitting look...
Any solid answer would be helpful.....
Old Mar 1, 2009 | 04:41 PM
MassScene's Avatar
Default Re: Hood for LSVTEC in CRX
IDK what the problem is with your oem hood....but i had a 91 SI w/ a GS-R Swap w/ Hasport's and a OEM hood and it was perfect for me !
Old Mar 1, 2009 | 04:42 PM
slowcivic e g's Avatar
seems like with most mount kits the stock usdm hood fits fine some just get a little rub mark on the valve cover. other than that, should be completely fine.
Old Mar 1, 2009 | 09:00 PM
B16Drag's Avatar
I dunno... Wish it was just a rub. I couldn't close the hood! I have an 88 CRX HF. Any confirmations on VIS or Seibon CF Hoods?
Old Mar 2, 2009 | 07:27 AM
LA_HONDAS's Avatar
the new hasport motor wont let you close the hood without spacing it up
ill sell them and buy avid ,az race ,etc, etc mounts
Old Mar 2, 2009 | 08:33 AM
NABeastRR's Avatar
thats cuz the axel alignment is straighter! take the good with the bad. or get a sir hood
Old Mar 2, 2009 | 10:25 PM
B16Drag's Avatar
I'm glad they make my axle alignment straighter!
To the original question, can someone confirm or deny whether the VIS CF SiR style will fit on a USDM CRX with LSVTEC and hasport mounts? I do NOT want to put washers on the CF hood either!
Old Mar 2, 2009 | 11:01 PM
MyLilCivic's Avatar
YES it will fit you will need to get the SiR hood for the USDM front end. I have had mine on for about a year.before i got my hood when i just had the stock USDM hood all i had to do was cut the webbing out under the hood and it closed but was a very tight fit.
Old Mar 7, 2009 | 05:28 PM
spoonfedcrx's Avatar
In my 88hf with ls/vtec I had hasport mounts and ZC hood fit fine. Liked the ZC hood kinda different. Never had another hood on car so I dont know if there would of been clearance issues.
Some others Ive seen with variety of mounts just left a little rub mark on valve cover.
Old Mar 13, 2009 | 11:54 PM
bryse68's Avatar
please tell me that this is not a problem with innovative mounts also..............
Old Mar 14, 2009 | 05:54 AM
the_big_dl86's Avatar
ya dont know if u got ur answer or not but i have the vis hood on my rex with lsv and it fits
Old Apr 25, 2010 | 07:14 AM
CrimsonRX's Avatar
I too have an LSvtec in a 90 CRX with innovative mounts and needed a hood to clear the motor.
I used a VIS hood and it clears no problem no spacers or cutting hood ribs. This is what I used.
VIS Racing US (SiR) Carbon Fiber Hood: Honda CRX 88-91 HB
P/N: 88HDCRXHBSI-010C
jacksonww
Apr 13, 2011 11:37 PM
VegaS10
Apr 4, 2006 10:23 AM
B18aHatch
16
Feb 10, 2006 11:43 AM
rhetorical
18
Sep 14, 2004 09:32 PM
apexinghonda
May 24, 2004 01:28 PM
