intermittent brake failure
Old Mar 1, 2009 | 09:18 AM
h22lude317's Avatar
Default intermittent brake failure
so i was driving around my development and my brakes all of a sudden gave out. I had to pump them to get anything out of them and slowly stop.
when the car is just sitting parked the brakes feel fine.
i replaced my slave cylinder cause the bleeder screw wouldn't come loose
the fluid in the master cylinder seems to stay at the same level, kind of dark though.
anyone know whats going on?
im going to try and bleed the brakes to just make sure its not that.
Old Mar 1, 2009 | 10:43 PM
cardudelude's Avatar
Default Re: intermittent brake failure
bleeding it should work do it a couple times to make sure you have all air bubbles out cuz thats what it sounds like
Old Mar 2, 2009 | 01:53 AM
TheJGB3's Avatar
The slave cylinder is part of the hydraulic clutch system not the brakes.
Old Mar 2, 2009 | 07:17 AM
h22lude317's Avatar
someone asked me in another thread if i replaced my slave
i know it compresses when the clutch is engaged
but thanks ill try to bleed them when this snow clears up in jers
hopefully that will work
Old Mar 2, 2009 | 07:26 AM
TheMuffinMan's Avatar
He knows where you live!
It's possible it's an internal seal failure in your master cylinder. The fluid just goes right back into the reservoir so you don't notice a loss of fluid. I'd swap it out real fast and you should be good.
Old Mar 2, 2009 | 12:36 PM
InvaderTrax's Avatar
Unless he's done recent brake work, there's no reason for there to be air in the system. More than likely it's the MC
Old Mar 2, 2009 | 04:16 PM
h22lude317's Avatar
swapped a rotor thats all
Old Mar 2, 2009 | 08:08 PM
i had air in my brake lines even i had not changed the brakes for like 5 months
Old Mar 2, 2009 | 08:33 PM
h23prelude's Avatar
if you have checked everything brake related and cannot find anything wrong try this,
some times when a wheel bearing is loose it will push the rotor into the caliper and it will compress the piston into the caliper, therefore when the brake pedal is depressed it will have to "fill" that gap causing a very low intermittent pedal feel.
but first check your MC and make sure your pistons move freely in the calipers.
this situation just happened to my Tacoma last week
Old Mar 2, 2009 | 09:06 PM
jlude90's Avatar
booster?
if you hit the brakes hard do they stop more normal?
pedroa06
Sep 3, 2009 06:23 PM
94lspower
May 19, 2007 08:42 PM
asianalbutt
Jan 12, 2006 12:51 PM
candy eg
Dec 27, 2005 07:32 PM
MrIllegalX
Aug 24, 2003 06:27 PM
