S300 datalogger
Old Mar 1, 2009 | 08:41 AM
Weel's Avatar
Default Sorted
Sorted
Old Mar 1, 2009 | 09:45 AM
mtber's Avatar
Default Re: S300 datalogger
Originally Posted by Weel
Hey,
whats the easiest way to wire a switch for datalogger on p30 jdm ecu on hondata s300?
Just had full tune and scared to destroy the ecu.
All you have to do is setup the variables & wire a switched input into the ecu.
If you are not confident enough to do it, contact your tuner.
Old Mar 1, 2009 | 04:25 PM
postman's Avatar
toggle switch between ground and pin for p/s pressure switch is any easy one. then setup in your parameters
Weel
Engine Management and Tuning
Nov 30, 2009 09:10 AM
nitewolf
12
Nov 21, 2009 08:55 PM
TypeRuz
Apr 24, 2004 04:26 PM
