turbo oil feed line
oil feed lines usually plug in where the stock oil pressure sensor is on the back of the block, and then hook in to the turbo at the center section.
for the oil sensor you have to use a t fitting to allow the stock sensor to still work, and have a spot for the feed line to connect in before the sensor.
its next to the oil filter
this is the sensor
read this for more information.
https://honda-tech.com/forums/forced-induction-16/complete-how-turbocharge-your-honda-rep-ing-hypnotik-speed-1263795/
this is the sensor
WTF size is the sensor, i havent been able to get it off after like 2 hours. I dont have a socket that will fit and none of my tools can get up in there and get a good grip on it.
Looking at the pictures you might need those special wrenches used for fuel lines, I have them but don't know their specific name.
I dunno. but the size for a d series oil pressure sender is supposed to be a 27mm star, instead it was a 3/4th star (i guess) because it fit my dads 3/4th open end wrench.
stealthmode62
Oct 3, 2011 06:14 AM
