Opinions on Aluminum Exhaust Piping...
Old Mar 1, 2009 | 01:15 AM
C_Rock77's Avatar
Default Opinions on Aluminum Exhaust Piping...
I've seen where a lot of people building cars go with Aluminum exhaust piping to save the weight over Stainless or Mild steel....especially when you're talking about 3" or larger piping. I know that weight is the advantage. What are the disadvantages of going with aluminum for piping?
Would that be something you guys would or would not recommend for a STREET car?
Old Mar 1, 2009 | 08:04 AM
vtec8200's Avatar
Default Re: Opinions on Aluminum Exhaust Piping...
it's much softer and gets dented up easier, it might be a bit more expensive too, the welder might charge more since its a bit harder to weld.
Old Mar 1, 2009 | 10:28 AM
squeezedeghatch's Avatar
heats up quicker than mild or stainless will. definitely more expensive to buy and fabricate.
Old Mar 1, 2009 | 08:02 PM
JLSpecialties's Avatar
Aluminum dissipates heat faster which is usually a negative when dealing with exhaust. More heat inside means more velocity for more power. Stainless holds in heat better then mild and thats why stainless makes more power then mild steel.
Old Mar 1, 2009 | 08:05 PM
bossm's Avatar
k lhtperformance makes stainless steel 2.5in piping for 495+tax and the 2.5 aluminum is 550+tax and they have tested it on 600whp cars for 2 years with not one single problem with it and also the stainless weight in at 28 with no muffler while the aluminum only weighted in at 8 without muffler
Old Mar 1, 2009 | 08:11 PM
flatblack-h22's Avatar
so, 3in stainless or 3in aluminum?
Old Mar 2, 2009 | 09:26 AM
stainless. its only 20lb difference, i mean if your a **** about weight than go aluminum, but stainless will give you more for your money.
K-teller FTW!
Old Mar 2, 2009 | 10:29 AM
FST GSR 1's Avatar
Make your own SS exhaust FTW.
Old Mar 2, 2009 | 12:13 PM
patriot's Avatar
Make your own aluminized FTW.
dso
Jan 5, 2005 09:56 PM
navin
Jul 3, 2003 07:35 PM
drjondurst
Mar 14, 2003 10:32 AM
B18C5-EH2
34
May 1, 2002 06:16 AM
boost killz
Sep 27, 2001 05:26 PM
