Opinions please!
Old Feb 28, 2009 | 05:51 PM
SD_Lurker's Avatar
HT White Ops
Default Opinions please!
Well after much deliberation I've come to the conclusion that I can buy a Diversion 165 right now or wait god knows how long to get a Dynasty 200DX. I don't have the money for one right now but I can get a Diversion tomorrow if HT welders give me the OK. Should I wait or will the Diversion be sufficient enough for welding little things. Mostly be used for brackets, charge pipes, mufflers/exhausts and so forth. I was thinking I can master the art of TIG with this machine and in the near future purchase the Dynasty 200DX. Please HT welders, give me your advice on what I should do. Have a good night boys.
Old Feb 28, 2009 | 07:20 PM
ToxicFabrication's Avatar
OG Fabricator
Default Re: Opinions please!
get the diversion man, i have one and have no problems with it what so ever.
welded this with it today
just make sure when you get it, get the foot switch with it as well as a nice gas lens, i also got a nice flexhead torch
Old Feb 28, 2009 | 07:45 PM
SD_Lurker's Avatar
HT White Ops
What material is that? How many passes? It looks like 1.. From what I was told, it doesn't matter the thickness of the material it will just take that many more passes with a smaller machine. With the exception of T joints the Diversion can do just about anything a bigger machine can do just takes longer. Am I correct in making such statements? This is what I was told, its not something I read so it may not be true.
Old Feb 28, 2009 | 07:50 PM
JDM KID 510's Avatar
Sch10 304ss
Old Feb 28, 2009 | 07:52 PM
OG Fabricator
single pass, thats not true. i do t-joints, lap joints all day no problem. its all in the heat control. it goes to 165 amps. so it can weld anything from piping all the way to cages. the material in the pic is Sch10 304 stainless steel 1.5" i have a big gas lens and cup on it with a flex head on it. works great for car fab and much more.
Old Feb 28, 2009 | 07:56 PM
The Diversion 165 can weld material as thin as 22 gauge and as thick as 3/16-in.
Old Feb 28, 2009 | 07:59 PM
OG Fabricator
well there you go, ive welded thinner ive only been tig welding for a month and a half
Old Feb 28, 2009 | 08:12 PM
m R g S r's Avatar
Just don't plan on doing a lot of aluminum with the 165. Well thick aluminum at least. Maybe some sheet for end tanks and possibly intake manifolds and charge piping, but no thick stuff. Aluminum requires a lot of current.
For steel you should be fine. Again on most of the thinner stuff. And by the time you need more power, your air cooled torch will most likely be too hot to hold, and it would be time to upgrade that to water cooled as well.
So I say the diversion should be fine for your needs.
Old Mar 1, 2009 | 07:39 AM
OG Fabricator
well put
sdubfid
Welding / Fabrication
Aug 17, 2009 06:28 AM
racerxadam
Jan 9, 2009 11:08 AM
xxbulaxx
Oct 29, 2007 09:06 AM
paulzy
Jan 29, 2003 09:31 PM
krshultz
82
May 9, 2002 06:03 AM
