just completed my mpfi swap!
Old Feb 28, 2009 | 05:02 PM
builtsinglecam's Avatar
Default just completed my mpfi swap!
i just did an mpfi swap except now i have a problem ok look i have everything correct on it such as wiring and ecu wiring but it starts up perfect and good but when its warmed up when you rev it up to 3000 rpm some where pass that it sputters out dont know why could it be a the TPS sensor?
Old Feb 28, 2009 | 05:04 PM
93formula's Avatar
Default Re: just completed my mpfi swap!
check your wirirng again you got your tps wires reversed more then likley.
Old Feb 28, 2009 | 08:25 PM
any one else can help?
Old Feb 28, 2009 | 08:46 PM
bobbyisking's Avatar
is there a check engine light on? i'm almost certain it is the iacv, or the idle air control valve. the same exact thing happened to me after my conversion and swap. the iacv engine code was on, but the wiring was correct. car started up fine, idle'd fine, but when i tried to rev it up, it would sputter and bog. so i decided to run a wire straight to the ecu and it fixed it.
Old Feb 28, 2009 | 10:58 PM
traxxasx's Avatar
limp mode check injector clips
SeraphimKidd
Jul 8, 2012 12:55 PM
"goose"jay
Feb 23, 2011 01:38 PM
footstinker
Sep 11, 2010 11:12 PM
blue_hatch
Jul 4, 2006 06:55 AM
BlkslowCRX
Jul 5, 2003 06:43 PM
