lower control arm question
Old Feb 28, 2009 | 04:33 PM
efjones9's Avatar
Default lower control arm question
would 92 civic lca's fit a ef? even jus temporary use?? help me out please!
Old Feb 28, 2009 | 09:29 PM
efjones9's Avatar
Default Re: lower control arm question
anyone???
Old Feb 28, 2009 | 09:41 PM
MeanstreakCivic's Avatar
in the rear?
Also what year car do you have? If its a 88 you need Type R
If its 89-91 then yes you can use 92 civics.
Hope that answers your question
Old Feb 28, 2009 | 09:59 PM
jdmed3's Avatar
wat year type r do you need i have 88 but possibilites for 90 suspension swap for convenience
Old Mar 1, 2009 | 01:18 AM
thisiskev's Avatar
Originally Posted by MeanstreakCivic
in the rear?
pretty sure you can stick any 89-95 civic rear lca's on a 88 rex. or any 94-01 tegs lcas and everything should work fine as long as you have 89+ rear shocks.
not 100% positive though. if someone else could confirm it, that would be good.
Old Mar 1, 2009 | 10:06 AM
efjones9's Avatar
ok thanx to all i have a 90' dx the 88 lca's didnt fit had to grind down the bushings to make it fit. long *** day because of those cheap *** ebay lca's
Old Mar 1, 2009 | 10:11 AM
LOL yeah cheap parts never fit right. OEM or legit aftermarket is the best.
Glad you got it figured out.
Old Mar 1, 2009 | 10:14 AM
efjones9's Avatar
ill post pics up later. it looked horrible!
Old Mar 1, 2009 | 11:00 AM
fabtoys's Avatar
my 88 4dr had stamped steel ones and I swapped them to 98 integra gsr arms ,sway bars ,struts (due to struts go around the arms on 89 -98 )
Old Mar 1, 2009 | 11:10 AM
efjones9's Avatar
this is all thats left of the ebay lca
Old Mar 1, 2009 | 12:09 PM
radex7's Avatar
Holy ****!
Old Mar 1, 2009 | 04:47 PM
gearhead16's Avatar
wdf did u do
Old Mar 1, 2009 | 08:01 PM
efjones9's Avatar
Originally Posted by gearhead16
wdf did u do
went over a speed bump at like 15mph! i was like wtf???
Old Mar 1, 2009 | 08:58 PM
jdmed3's Avatar
welcome to the world of honda's if your ***** lowered you go sideways over a speedbump and somewat slowly cuz look wat happens
88hbz6
Suspension & Brakes
Jan 17, 2008 03:39 PM
primetimedx
11
May 24, 2006 09:37 PM
Deo
12
Sep 22, 2005 10:43 PM
DeKaP
Aug 26, 2004 06:57 PM
Heavy Pee
Jul 30, 2003 08:20 PM
