stock eg wont start
Is your battery charged? Hard to picture what a bloomp sound is but I hear a small crank that sounds like a bloomp I guess when my battery is dead, thats the starter motor trying to crank the motor but when it has no power it dies. Maybe its your started motor thats gone or your battery.
A motor needs 4 things to start: Fuel, compression, spark, and timing. If youve got fuel, and compression and your timing is fine then its usually the spark. So it could be anything in the ignition area, spark plugs, distributor, starter motor, grounds,etc.
everything checked out, turns out, I cranked the motor at WOT and it starts fine now... car never turned on for about 6 months, plugs look a little fouled as well
civic89si666
Sep 27, 2006 02:54 PM
