best 1/4 mile time in stock itr.
Old Aug 11, 2002 | 01:12 AM
Mr.Sha007's Avatar
Default best 1/4 mile time in stock itr.
what was the best time you guys put up in a stock itr? i did a 15.9 in my e30 m3 at lacr ( times are way off up there) and i just wanted to compare the two cars.
Old Aug 11, 2002 | 01:16 AM
ITR 2K's Avatar
Default Re: best 1/4 mile time in stock itr. (Mr.Sha007)
15.9 seems horrible. How off were the times? It sounds as if they were off by a whole second. I've seen stock ITR's run somewhere in the vacinity of 14.5 to 15's.
Old Aug 11, 2002 | 01:26 AM
AllMotorITR's Avatar
New User
Default Re: best 1/4 mile time in stock itr. (ITR 2K)
Lowest I've seen a stock R do is 14.4
Most people hit between a 14.5-15 flat.
Old Aug 11, 2002 | 01:32 AM
Montreal R's Avatar
Default Re: best 1/4 mile time in stock itr. (1 FAST R)
saw 13.9 stock (with the exception of the Power Steering Pulley that had been removed)
The guy had it Dynoed at 170.4 @ 7800 rpm with 119.4 wtq @ 7200 rpm
[Modified by Montreal R, 5:45 AM 8/11/2002]
Old Aug 11, 2002 | 01:44 AM
hybrider's Avatar
Default Re: best 1/4 mile time in stock itr. (Montreal R)
wow, impressive
best ive seen is a 14.6 (totally stock), and another R with a cai at 14.1
Old Aug 11, 2002 | 02:18 AM
Mr.Sha007's Avatar
times are by about 5 tenths, but thats my m3 that ran that time, plus i have huge and heavy 17's. i just want to see where i stand.
Old Aug 11, 2002 | 02:36 AM
01PYITR's Avatar
14.71 is my best so far and I average 14.99, just cant bring my self to say 15.00
Old Aug 11, 2002 | 04:40 AM
Euro98ITR's Avatar
I did 14.1ET @99.5 Mph with a Euro Spec ITR with just an AEM CAI and no CAT.
Also ! I used stock tires RE010!! The 18deg timing also helps a lot i think.
[Modified by SF-ITRB18c6, 7:21 PM 8/11/2002]
Old Aug 11, 2002 | 05:27 AM
MyYellowHonda's Avatar
New User
Default Re: best 1/4 mile time in stock itr. (SF-ITRB18c6)
Wow.. i didn't know a CAI could make that much of a difference.
Old Aug 11, 2002 | 06:01 AM
Stumpy's Avatar
Default Re: best 1/4 mile time in stock itr. (MyYellowHonda)
Didn't ActiveAero run a 14 flat with an AEM CAI?
Old Aug 11, 2002 | 07:59 AM
DaRKniGhT ITR's Avatar
Default Re: best 1/4 mile time in stock itr. (Stumpy)
14.8 here in the sweltering heat and humidity of Miami, bone stock...and on the first week i got it...
Old Aug 11, 2002 | 08:13 AM
uNF$@#!'s Avatar
Default Re: best 1/4 mile time in stock itr. (DaRKniGhT ITR)
15.101 <-- best time i've seen in a ITR.
[Modified by Soup ****, 12:13 PM 8/11/2002]
Old Aug 11, 2002 | 08:34 AM
jonas's Avatar
Default Re: best 1/4 mile time in stock itr. (Soup ****)
i believe RagingAngel on this board did a 14.4 BONE STOCK
Old Aug 11, 2002 | 08:42 AM
Jmm0056's Avatar
AcitveAero ran a 14.0 with a homemade intake and free mods
Old Aug 11, 2002 | 09:25 AM
Euro98ITR's Avatar
Default Re: best 1/4 mile time in stock itr. (Jmm0056)
Do u think I should go down to 13.9 with a DC JDM header and some performance tires??
Old Aug 11, 2002 | 10:40 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
14.03@99.35mph with AEM CAI, not cat, and PS belt removed.
Have also hit a 14.3@96mph with exhuast hooked up and a 110lb passenger on a 75 degree night.
Old Aug 11, 2002 | 10:44 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Well the intake was an AEM at one time. Then the Bypass valve broke and I put it back togther with hose clamps and wrapped it with some of that tin foil looking tape.
Oh and my first 14.0 run was with a bad distributor coil and throwing a random misfire code . (apparently not on that run though)
Old Aug 11, 2002 | 11:47 AM
fitzuni's Avatar
New User
best time 14.35 @ 96 2001 itr
14.09 @ 98 2001 silver S2000 <sold>
BOTH CARS STOCK
soon 2003 lsb M3 >>>>>>>>>>>>&g t;>
Old Aug 11, 2002 | 11:48 AM
jonas's Avatar
Default Re: best 1/4 mile time in stock itr. (fitzuni)
stock.. full interior.. power steering belt still on.. yada yada yada?
Old Aug 11, 2002 | 12:31 PM
HondaCivicEx98's Avatar
New User
In Lacr, i have seen type r run mid 15's in a hot summer time
I will assume those are stock.
15.9 on ur E30? i think u could still do much better.
Old Aug 11, 2002 | 10:23 PM
Rhetoric's Avatar
Default Re: best 1/4 mile time in stock itr. (HondaCivicEx98)
My friend hit a 13.9 with just weight reduction (excessively reduced, car weighing about 2300), ram air through his high beam. Stock header,ecu, intake(kind of), cams. He might have had a 5 zigen axle back and a test pipe at the time.
Old Aug 12, 2002 | 04:48 AM
MPH's Avatar
MPH
New User
15.0 bone stock
Old Aug 12, 2002 | 05:29 AM
BryanSprinkel's Avatar
Default Re: best 1/4 mile time in stock itr. (MPH)
14.21 with JDM header and carsound cat. All interior, and belts ON the car.
I think 14.6 stock, cant remember.
Old Aug 12, 2002 | 05:57 AM
H-PIMP's Avatar
Default Re: best 1/4 mile time in stock itr. (BryanSprinkel)
Best I've ever seen was Speedracer0067's car that ran 14.0 @ 98 w/ a modified stock airbox and APEXi N1 cat-back, I think he ran 14.4 completely bone stock.
Best I ran bone stock in my '00 was 14.6, I can now turn 14.3's relatively easily w/ CAI, test pipe, and 5 Zigen muff.
My '98 was a bit quicker than my '00, that car ran 14.1 @ 99 w/ a hollow cat, no a/c, and SRI. Now that car was a rocket! I miss that car!
Old Aug 12, 2002 | 05:05 PM
Mr.Sha007's Avatar
well you have to realize i have very heavy rims, plus its time for a valve adjustment and timing chain on my car. POOP! lol. man alot of these times are great! you guys should come out to LACR and run, i bet no one would hit 14's in a close to stock ITR.
henRRRRy
May 9, 2005 01:39 PM
FF DRFT
Jun 23, 2004 09:13 PM
BassBoy19
May 24, 2003 07:31 AM
TypeR Chris
Jan 12, 2003 09:36 AM
uncleben
16
May 13, 2002 08:37 PM
