Would a del sol rear trailing arm swap in to a 97 civic ex??? (rear disk swap)
i did a search............nothing came up with the del sol.....
Got my hands on a set of rear trailing arms w/ the hub, disk brakes...etc off a del sol.....i have no idea what year is the del sol. Just wondering if it would fit on a 97 civic ex. Are they the same as the 99+ si rear disk brakes? Do they use the same pads/Caliper/disks as the si? Which prop. valve should i use? I have been told that my stock one will do, but its better to get a Prop valve from a car with rear disks. SO which Prop. valve should i use? Si or del sol???
have any of you guys did a del sol rear disk swap into a 6gen civic yet?
well......any help on this topic would be a lot of help
thanks
thanks
Slow Egg
Oct 6, 2002 09:29 AM
