Turning signal is acting wierd Need helppp
Old Feb 27, 2009 | 11:03 PM
SingleCamin's Avatar
Default Turning signal is acting wierd Need helppp
here is a question i found on google that is similar to my problem
Maybe someone has run into this problem already, it does it occasionally, you turn the switch on and it will work and then another time it wont or it will cause the opposite side to flash or the lamps will flash but the console arrows will not illuminate.
Any thoughts?
Old Feb 27, 2009 | 11:46 PM
Default Re: Turning signal is acting wierd Need helppp
Old Feb 28, 2009 | 07:20 AM
Old Feb 28, 2009 | 07:29 AM
Jonknee's Avatar
There are little relays bolted on beside your headlight(they're black , small and i think 2 of them) Wiggle them to check if they're loose.
Old Mar 1, 2009 | 01:04 AM
ill do that
Old Mar 1, 2009 | 08:30 PM
its still doing it !!?
D16SohcVtec
Apr 16, 2009 06:11 PM
kdesh88
Mar 12, 2008 07:35 AM
tyco
Sep 12, 2006 09:57 PM
ZipTieGUy
Feb 8, 2006 08:26 PM
dbest1
May 19, 2004 05:51 AM
