Turn Signal Problem
Turn Signal Problem
I have a problem with my turn signals, when I turn on the directional signals they don't work until like 5 seconds later and then they work. My hazards work fine. They work when I push down the button. But my turn signals just have this wierd 5 second delay. Has this happend to anyone before?
My specs are
1993 Del Sol
NRG hub
wideband O2 powered my option C spot in fuse box
stock everything electrical
My specs are
1993 Del Sol
NRG hub
Re: Turn Signal Problem
either check to make sure u have the right bulbs in there maybe there is two differnt kinda causing the problem or maybe ur turn signal switch is going bad they often go bad quite regular search aound
See the yellow symbol with a picture of a mountain in it (see picture below). Click that symbol and paste you picture link from Photobucket or some other site that allows you to upload pictures.
I hope this helps you... https://honda-tech.com/forums/showthread.php?t=2530751
