B series swap problems
K been working on my project for 3 years now and i finally have time to finish it
91 crx with b16a1 cable trans
was told to you 90-93 teg clutch cable does seem to fit right or im hooking it up wrong picture of how its suppose to look would be nice
drivers side wire harness in engine bay i have 2 extra plus and no idea what they go to they both have same color wires going to them
searched for answers but new search doesnt work so good so if you can help me let me know
its a dx and thats hooked up the looks like the corner light clips but those are there looked at my civic today and they could be for washer fluid or one has to be or is there 2 plugs for that
Well that depends, I am not sure on DXs but on SIs there are two plugs for the washer fluid, one for the front and one for the rear. Also you said engine bay not wheel well.
check the end that goes on the clutch pedal, cant remember if the da one is different from the ef or if thats only the accelerator cable....
edit: looked it up on worldpac, seems like the pedal ends are the same the only difference is the rubber grommet that goes on the firewall, if you already have it im sure you can make it work.
ends are the same if i could get a pic of how it hooks up to the trans would be nice i got 2 more honda cables today from a buddy just not to sure if rubber is supposed to be in slot or metal
tek_civic
Apr 18, 2006 12:38 AM
thumbtack
Aug 12, 2004 02:02 PM
ham
24
May 11, 2004 09:20 PM
