idle problem b16a
my car runs fine until i get off the highway or after i enter vtec but when it comes time to stop the idle fluctuates from 1k to 2500 sometimes. i took off the iacv and cleaned it out with brake cleaner, let it dry out for 2 hours and messed with my sunroof trying to get it to open, then put it back on. it does seem less rough but the problem still remains. should i just buy a new iacv or is it something else? if someone could tell me how to check for a vacuum leak that would be awesome.. also i want to try to change the tps but idk which ones are interchangeable between honda motors, can someone please help with this...thanks
make sure your coolant is full and no air in the system, also check your fiv http://www.jdmuniverse.com/forums/ho...-idle-fix.html
crxguy406
Sep 10, 2015 03:56 AM
darkintegra94
16
Sep 23, 2009 08:32 PM
