96 Civic Idle Problem!
Old Feb 27, 2009 | 02:28 PM
charley79boo's Avatar
New User
Default 96 Civic Idle Problem!
I have a 96 civic dx, it idles real funny. I start it and it idles fine, after about 5 minutes it starts idling high then normal, high then normal. I have ruled out a vacuum leak by tryin about 5 different procedures. There is no check engine light on. When I do unplug the map sensor it idles fine... so I replaced the map sensor hoping it would fix the problem, and yet it hasnt. Any ideas guys? ( and it still idles normal when I unplug the map sensor.)
Old Feb 27, 2009 | 04:14 PM
Former User's Avatar
Default Re: 96 Civic Idle Problem!
Try cleaning the IACV on the throttle body and also topping off and bleeding the cooling system.
Old Feb 27, 2009 | 06:06 PM
ccarey's Avatar
replace the IAC valve
Old Feb 28, 2009 | 04:39 PM
New User
I have indeed cleaned the IACV, and also have bled the cooling system and topped it off. The problem persists. My lights are also dimming with the idling issue. Possible alternator bad? this is a headdddache!!!!!!!!!!!!!!
Old Feb 28, 2009 | 08:47 PM
AutoZone will check your alternator and battery free of charge.
Is the engine overheating or loosing coolant?
How did you bleed the cooling system?
Have you tried adjusting the idle screw on the throttle body?
blomer
Mar 30, 2018 11:31 AM
greenzchatch
Jul 29, 2010 02:14 PM
skippysg
May 27, 2010 06:52 PM
bads2k
Feb 2, 2010 10:07 AM
mikeunreal
Oct 27, 2005 02:39 PM
