B16a2 swap in eg part list
Old Feb 27, 2009 | 10:58 AM
1993b16bubble's Avatar
New User
Default B16a2 swap in eg part list
i have a b16a2 from a 2000 si and im putting it into a 93 hatch can you guys help me with every part i need to finish the swap
parts i have:
b16a2 motor tranny
b16a2 motor mounts(2000) and jdm b16a motor mounts(1992-95)
b16a2 axles
b16a2 ecu
b16a2 engine wire harness
what else do i need?
Old Feb 27, 2009 | 04:00 PM
94EG8's Avatar
Seagull Management
Default Re: B16a2 swap in eg part list
You can't use the Si engine harness (you can probably sell it in the H-T marketplace though, someones always looking for one) Use a '96 - '99 Integra engine harness (GS-R or ITR if you don't want to have to wire vtec in the engine harness.) You will also want a B16A3 or B16A OBD1 ECU (P30)
Old Feb 27, 2009 | 04:09 PM
CA6VTEC's Avatar
parts i have:
b16a2 motor tranny
b16a2 axles
b16a2 ecu
Use the stock Harness from you hatch and modify accordingly.
You can use everything, but the harness & ecu. OBD1 P30's are hard to find, maybe you can use a chipped P28 or GS-R Ecu.
Old Feb 27, 2009 | 05:09 PM
94EG8's Avatar
Seagull Management
If it was an OBD1 engine i'd agree with you. But in the case of an OBD2 engine in an OBD1 chassis it really doesn't get any slicker than an OBD2A Integra engine harness (plugs into both the civic shock tower plugs and all the OBD2 components on the engine)
Old Feb 27, 2009 | 05:22 PM
CA6VTEC's Avatar
Only differences is the OBD2 sensors that the OBD1 Ecu WILL NOT look for. So an OBD1 Harness is perfect. Only difference is the Alt, Dizzy & Injectors Plugs. If he can find an OBD2 teg Harness, than go for it, OBD1 Dizzy & Alt can be had for less than the Harness IMO.
highmfer
10
Jun 27, 2011 03:15 PM
12three
28
Mar 27, 2011 11:55 AM
v-tec maz
Dec 31, 2005 04:29 PM
origyns
Jul 19, 2005 08:44 PM
