type r cams
Old Feb 27, 2009 | 08:27 AM
ef-hatchcrap's Avatar
Default type r cams
I just got some type r cams for my b16 I need to know if I can use my pr3 cam gears or do I have to get type r cam gears?
Old Feb 27, 2009 | 09:21 AM
EL Vap133's Avatar
Default Re: type r cams
You can use the pr3 cam gears, that is what I did and they work fine.
Old Feb 27, 2009 | 09:36 AM
ok did you have ti adjust your valves to the cams because I have heard yes and no I just want the right answer
Old Feb 27, 2009 | 09:48 AM
Dark_Teg's Avatar
If you are installing cams why wouldnt you go ahead and adjust the valves. The right answer is "inspect what you expect". and you will never be let down.
Old Feb 27, 2009 | 10:40 AM
I just did a valve adjustment not 5000 miles ago
Old Feb 27, 2009 | 12:47 PM
autoxthis's Avatar
I believe since the cam lobes are a different profile, you would need to readjust your valve lash to the new type R specs profiles. Anyone else on this?
Old Feb 27, 2009 | 01:05 PM
Black4thgenEF's Avatar
If they are still in spec it will take all of 30 seconds to check them with a feeler gauge. Why wouldn't you?
Old Feb 27, 2009 | 04:59 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Sure the lobes are different, but the base circles didn't change. On the contrary, you are absolutely crazy if you think just because you did it 5,000 miles ago that you won't need to do it again when you are changing the camshafts. There are almost always grinding imperfections or variances in mass production products.
I would take it to a competent mechanic to do the camshaft install for you. I don't believe you have the capability to do it correct yourself, not being a jerk but…
Old Feb 28, 2009 | 06:24 AM
Well little do you know that I am a very well qualified mechanic. Installed cams re-adjusted the valves she runs like a top going to get her tuned on monday
Old Feb 28, 2009 | 11:35 AM
ef_junky's Avatar
well if your a very well qualified mechanic then why did you ask that question? you should have already know you needed to do it, especially if your taking off the cam cap/rocker arm assembly you should at least check it.
Old Mar 1, 2009 | 07:27 PM
brixcivic's Avatar
valve lash!! yes u have to re adjust ur valves after insalling them. secondly do not rev past 8500 might get some valve floatage.. type r heads came with better valve springs to handle them... with that all said slap em on adjust urself reall easy jus need a feeler gauge an patience.. start it an hear how hard vtec gonna pop
Old Sep 24, 2009 | 10:56 PM
Scott_Tucker's Avatar
Yes, he should adjust his valves. Just because the valve train is quiet and it runs well does not mean they are adjusted correctly. If they are too tight they arent going to make any noise. But if he goes on a hard run, the temperature of the exhaust valves will rise, the stems will get longer due to the temperature increase which closes up the lash, and the exhaust valves will be kept off their seat which causes hot exhaust gases to rush by the gap between the valve face and seat. This can quickly lead to a burnt valve. So it would be foolish not to do it unless you don't care about the engine.
EDIT: Sorry, I just realized you did adjust the valves. But that still applies as to why you should.
Old Sep 24, 2009 | 11:15 PM
Bunger's Avatar
Yeah, check the lash, it doesn't take very long at all.
rookshot06
Jul 18, 2008 06:25 AM
DCtooD
Oct 9, 2006 05:44 AM
solofthesouth
10
Dec 28, 2005 08:58 AM
cr00klyn718
Mar 5, 2002 11:34 PM
xtrafastcivic
Feb 27, 2002 04:53 AM
