almost done wit allmotor build few things still needed tho!
14.5 compression 92mm stroker kit pro3 cams have c16 prolly gunna use q16 wondering wat plugs to use have bkr7e11 ngk not sure if these are wat i should be runnign at this compression.
also wat oil should i run conisder i wont be leaving the oil in the motor for more than 1 event day.
thanks
thanks
doublezerohatch
Jul 1, 2013 08:03 AM
xEnderx
Jan 4, 2006 06:38 PM
