Does anyone know how to install pistons and rods?
Old Feb 27, 2009 | 05:36 AM
crxrider07's Avatar
Icon2 Does anyone know how to install pistons and rods?
I am trying to save money and i wanna try to install the turbo pistons and h beam rods in my d16a6. Does anyone know where i can find the info to do it online?
Old Feb 27, 2009 | 06:29 AM
Dark_Teg's Avatar
Default Re: Does anyone know how to install pistons and rods?
Its the same for every motor so there will be tons of info if you google it. If you are using aftermarket pistons and rods with a floating pin you will be able to do everything yourself just be careful and patient.
Its a good idea to get a fresh hone.
Old Feb 27, 2009 | 06:40 AM
mike-y's Avatar
don't forget to measure and gap the rings correctly for each cylinder. My pistons were press fit to the wristpin, so I just carried them down to the local machine shop, and they did it in 5 minutes for like $25.
Old Feb 27, 2009 | 06:46 AM
B16CRXT's Avatar
most forged pistons come with wrist pics that have locking rings so there is no need to be pressed in. You need to make sure you have your rings in the proper sequence, spacing, and gap. Once everything is assembled, use a ring compressor and tape the rod cap off. then, put the rod in (slowly) the cylinder in the correct position and make sure you keep the ring compressor flush with the top of the cylinder or you will be frustrated(trust me I know), then just push/tap the piston down into the cylinder. Make sure you install the bearing on the rod and use assembly lube on it before you begin putting it into the cylinder though. Makes things much easier. the key is being careful not to scratch the cylinder walls, the bearings, or damage the rings or pistons. I ****ed up once and (because I was frustrated as hell) shattered a ring trying to tap the piston down. Had to buy a whole ring set just because of the one shattered ring.
Old Feb 27, 2009 | 07:03 AM
jhammond_82's Avatar
Reject Papi
its for a b series, but same idea!
http://www.youtube.com/watch?v=mpy_By5aIxM
Old Mar 14, 2009 | 10:44 AM
bossm's Avatar
evans tuning has the best diy videos to give you an idea of how to di it they are 100% on everything
civic-r11
Jan 28, 2009 06:33 PM
xbladr
Nov 29, 2004 12:58 PM
MiKeAhOwSkI
Aug 28, 2004 03:29 PM
the g2 teg
Aug 21, 2004 07:22 PM
95integrags-r
Mar 5, 2003 07:30 AM
