96 civic wont start after swap, help please
Old Feb 27, 2009 | 04:26 AM
crxfornow's Avatar
Default 96 civic wont start after swap, help please
Alright heres the deal, i replaced my d16y7 swap with a obd1 jdm d15b swap, i reused my y7 harness and extended the needed wires and did the iacv mod, i used the guts out of my y7 dizzy and put them in the z6 dizzy, i also have a p08 and a p28 ecu with the obd2a to obd1 conversion harness, with all this together my car will not start for the life of it
Things i have tried>
im getting fuel to the rail, ive pulled every plug and grounded them and im getting spark to every one, ive checked the three grounds a million times, the only check engine light is for vtec, but i havent wired that in yet, im using my known working injectors out of my y7, the car also wont start with the original obd2a y7 ecu. I have also checked to make sure my timing marks are on point and they are.
Basically im getting fuel, spark, air, and my timing is correct, and ive tired three different ecus, so now im stuck.
Any ideas would be great for what to look for, ive been qouted 250 bucks for a ex engine harness from a local scrap yard and thats looking like its the only thing that could be wrong with it but i dont want to spend that money if i dont need too
Maybe ive over looked something or there is something else i need to do for a obd1 d15b to work in a obd2a car
Lastly ive looked at all the threads pertaining puting obd1 motors in obd2 cars so please dont tell me to look at them
Any help would be nice
Old Feb 27, 2009 | 04:56 AM
94EG8's Avatar
Seagull Management
Default Re: 96 civic wont start after swap, help please
When you swapped the guts between the distributors, did you make sure you got the 2 pronged drive on the right way? you can 180 it out where its attached to the shaft with the pin. Should still fire, but the ignition timing will be off 180 degrees.
Old Mar 4, 2009 | 03:54 AM
crxfornow's Avatar
your good man that was excatly what was wrong, thanks man
Old Mar 4, 2009 | 05:13 AM
94EG8's Avatar
Seagull Management
No problem
Old Mar 19, 2020 | 10:27 AM
Anthony Hunt's Avatar
I have a d15b with a z6 head not sure what kinda of dizzy p2p ecu cranks and run my car but it’s running bad I have a p28 with d15b Vtec chip and it will not crank
mtdelsol
Jan 15, 2017 09:17 AM
88_hatch_ls
Jul 29, 2013 06:38 AM
reevear
20
Sep 19, 2011 05:18 PM
93formula
May 15, 2007 11:46 AM
headhunter
73
Jun 8, 2006 09:47 PM
