OBD0->OBD1 issue
Old Feb 26, 2009 | 06:39 PM
Mr. EF's Avatar
Default OBD0->OBD1 issue
I'm having an issue after wiring the Rywire Jumper harness to a 91 Integra with a 95 GSR swap...the car cranks and cranks and starts with a putter...i rewired the distributor over and over again to see if that was the issue and nothing...does anyone have the a write up on this or a diagram on both so I can match them up? Also im flashing a CEL code 20 which is ELD (Electrical Load Detector)...can someone help...I have never eperienced this issue before and have no idea how to troubleshoot it...
Thank You in Advance
Old Feb 27, 2009 | 09:18 AM
Mr. EF's Avatar
Default Re: OBD0->OBD1 issue
anyone?
Old Feb 27, 2009 | 03:14 PM
Blown90hatcH's Avatar
Code 20 will not cause those issues. What ecu are you running? Did you buy the distributor jumper from RYwire too?
Old Mar 6, 2009 | 07:07 PM
Mr. EF's Avatar
Yea i did get the rywire from rywire...P72... i keep getting code 4 and 9...CKP & CYP...rewired it like 20 something times with all these diffrent color code write ups...super pissed...
Old Mar 6, 2009 | 10:14 PM
Mr. EF's Avatar
just retimed the car...going to reset the ecm now...
Old Mar 18, 2009 | 07:17 AM
CRX VT-DOO's Avatar
How did you get on?
Old May 27, 2009 | 06:35 PM
smiley-da9's Avatar
New User
I NEED SOME HELP WITH MY DA9......
I HAVE A DA9 WITH A 98 GSR SWAP AND IT HAS AN ELD CODE...
I TOOK IT TO GET FIXED..BUT ALL THEY WERE ABLE TO DO WAS FIX THE WIRING AND THE VTEC.....BUT ALL I NEED IS TO MAKE THE ELD WORK...HELP
Old May 27, 2009 | 08:36 PM
seanbev24's Avatar
The ELD is located in the fuse box on the later cars. 90-91 tegs didn't come with them, so there are 2 ways to get rid of the code...
1. Chip your ecu and have the ELD disabled
2. Swap in a newer fuse box and rewire it.
I'd say that #1 is the only good option and that's only if you're chipping the ecu anyway. The ELD doesn't even make the CEL light up, so the only time you would see it is if you check your codes. It also has absolutey no effect on how your car runs.
cornfed
Engine Management and Tuning
Jan 27, 2012 02:49 AM
JustAnotherRex
17
Jul 9, 2007 04:15 PM
mike9571
Jul 9, 2007 09:05 AM
SolidSpruce
Sep 23, 2003 02:28 PM
