Edge of Crankshaft pulley Damaged
Old Feb 26, 2009 | 04:42 PM
nightime25's Avatar
Default Edge of Crankshaft pulley Damaged
While I was putting motor in "92 Accord" The edge of the crankshaft pulley got damaged/chipped around the lip for the powersteering pulley pretty badly. Would like to know if I should change it or get another one and how hard it is to get off?
Old Feb 26, 2009 | 06:47 PM
Terminator6742's Avatar
New User
Default Re: Edge of Crankshaft pulley Damaged
it pends on how big the chip is, if it's just a tiny section you should be ok but if its a reasonable chunk missing you should prolly replace it to be safe. They're usually not that bad to get off, normally an impact gun will take them of and then they just pull off, but watch you don't lose the keyway on the crank shaft. if you dont have an impact gun than you mite me able to use a breaker bar and snap it quickly to release it and if that doensnt work you may have to take it to a dealership, they have a special tool to hold it still while they use the breaker bar. hope this helps
natebaur
May 9, 2009 05:09 PM
DesertEG6
Dec 17, 2008 07:11 PM
lacking vtec
Mar 24, 2007 04:55 AM
f150harleytruck7
10
Dec 20, 2005 08:09 AM
EgSalad
22
Oct 7, 2005 05:03 PM
