ls vtec :(
Old Feb 26, 2009 | 03:39 PM
spicygirl's Avatar
New User
Default ls vtec :(
ok yet again i have problem with my car 1995 civic hatch ls vtec i ran a ls distributor it caused it to miss bad and it went out for some reason so i got a gsr for it now the car will not start i went to look at timing and it was off so i have rest it and it still will not run unless i am on the gas and even floored it will only rev up to 2k rpms and miss bad there is also a bad smell of gas n e one have n e ideas let me kno thanks
Old Feb 26, 2009 | 10:25 PM
hamawizard's Avatar
Default Re: ls vtec :(
you might need to change your spark plug wires. also your car is fuel injected dont give it gas when your starting it you will end up flooding your oil pan with gas.if you have been giving the engine gas you might want to check your oil you might need to change that also.
JMSI
Nov 18, 2014 03:17 PM
TYLER3
May 11, 2012 08:21 AM
dcforgod
Sep 26, 2008 12:41 PM
civiclxb16a
Jan 28, 2006 10:27 PM
4drlsvtec
Feb 2, 2002 08:49 AM
