Horn wire for keyless entry install?
Hi, I just installed a keyless entry by Valet and i haven't been able to find the wire for the horn.
Does anyone know what wire it is?
Where it is? EXACTLY
Pictures would help.
Ive seen that its in the steering column harness?.. Well, where is that? which one is it? Do i have to take apart the steering wheel?
Ive tried to get help already but its unsure. I even got the repair manual but the color wires dont go all the way down to the little sections. And i'm unsure of where they are either way.
Ive looked at installs and everything but they say little about getting to the horn wire. Id prefer to hook it up from the inside the car if possible. If going straight to the horn in front of the car, is what it takes then let me know how to get to it.
Thanks.
Thanks.
I don't see any black plugs. All I see is grey, grey, grey, green, brown, blue, yellow, and some more grey.
The green plug is on a black relay I believe it is. But no silver wire.
Am I going to be forced to open the steering wheel?
Does anyone know how to get to the horn wire without taking apart the steering wheel or wiring it straight to the horn.
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-wire-horn-nrg-short-hub-2402541/
picture is there, the plug connects to another harness at the SRS reel
i dont want to sound mean.. but could you show me where on my pictures? or something.. cuz i looked and looked and i just dont see it.. point me in the right direction? i dont even know which harness is the SRS..
I believe there should be 4 or so wire looms going into the steering wheel. It's been awhile since I did the mod myself but that cable is not long enough to stretch all the way up. You should see the connection somewhere near the igntion switch area for it.
so the plug im looking for is inside the steering wheel itself? .. can i get to the wires from outside the steering wheel or is there something i can take off easily to get to it?
the black plug? .. the only black plug i saw there is the little tiny black one in the middle of the picture on the bottom.. or is it hidding under and behind that green one?
jmeyer99
Aug 10, 2007 07:15 AM
JDM-EJ1
12
Dec 30, 2005 03:02 PM
