B20V Pointers
Old Feb 26, 2009 | 02:25 PM
VtecNotRequired's Avatar
Default B20V Pointers
I am currently running a B16A in my car but I am going to swap out the block for a B20B that I just put in the macine shop to get bored, re-honed cylinders, port and polish, micropolished b20b crank, type r oil pump and type r water pump. I am expecting a gasket kit in the mail tomorrow to re do all the gaskets. The only thing I am wondering about is a good rod/piston combo with this build. I am looking to run somewhere between 11.0:1 - 12.0:1 compression ratio and I want something aftermarket (not oem honda). what do you guys suggest? I am planning on a thin head gasket, itr exhaust cam, ctr intake cam, adjustable cam gears, skunk2 valves and retainers, type r intake manifold, passwordjdm cf whale *****, jdm itr vtec solenoid, PR3-2 head. thanks for the help
Old Feb 26, 2009 | 03:12 PM
CivSiClone_96's Avatar
Default Re: B20V Pointers
I know you said you wanted aftermarket piston rod combo but you should think about the RS machine ITR pistons they make them in 84, 84.5, 85mm and are at a decent price. Cant use aftermarket rods on them but the B20 rods will be fine with your setup just throw some ARP rod bolts in.
Old Feb 26, 2009 | 03:19 PM
Italix's Avatar
Yeah I second that, I think RSmachine pistons will do you good and invest the extra money you save into a quality header
Old Feb 26, 2009 | 03:22 PM
I can't find anywhere to buy the RS ITR for B20, i found a link to it here on honda tech but the links didnt work for the B20 pistons. I was looking for the 85 MM ITR RS machine just to check them out. any links?
Old Feb 26, 2009 | 03:30 PM
try searching ebay or call race axis and see if they still stock them for the B20 thats where I picked up mine.
Old Feb 26, 2009 | 08:04 PM
domokun!!!'s Avatar
i sure hope your not planning on going with 85 mm pistons on stock sleeves...
Old Feb 27, 2009 | 06:34 AM
bks84's Avatar
Loved
You can use aftermarket rods with RS pistons.
Old Feb 27, 2009 | 12:30 PM
ruffie_PL's Avatar
With no mods?
Old Feb 27, 2009 | 12:44 PM
Combustion Contraption's Avatar
Port and polished B20V block
Old Feb 27, 2009 | 01:13 PM
ALLxMOTOR EG's Avatar
Vietnamese!
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
Woody.
Jan 16, 2012 08:09 AM
Jdmb16sir2
Apr 16, 2007 04:58 PM
team-savage
26
Oct 25, 2006 08:32 AM
jaydmcrx
Sep 9, 2005 07:11 AM
OPTION2ek V.2
11
Apr 26, 2005 06:18 PM
