Wtf, is a 1998 Ex o2 sensor really different than a 1999 Ex O2 sensor?!?!?
Old Feb 26, 2009 | 01:01 PM
brookliner7's Avatar
Default Wtf, is a 1998 Ex o2 sensor really different than a 1999 Ex O2 sensor?!?!?
So, I just bought an o2 sensor online made for a 92-00 Civic.
HOWEVER, in my haste to get my car running, I STUPIDLY dismissed reading the more detailed applications, assuming that if it fit the OBDI 92-95's, and the 96-98 OBDII ex's, it would fit the 99-00 OBII ex's.
Here is some detail about the application of the one I am stuck with:
93-00 Honda Civic CX, 2-Door, 3 Door, California Models Only, 4 Door, California Model, Automatic Transmission, Manual Transmission
92-00 Honda Civic DX, 2-Door, 3 Door, 4 Door, Automatic Transmission, Manual Transmission
92-98 Honda Civic EX, 2-Door, 4 Door, California Models, 4 Door, Except California Models, Automatic Transmission, Manual Transmission
99-00 Honda Civic GX
96-00 Honda Civic HX, Automatic Transmission
92-00 Honda Civic LX, 2-Door, 4 Door, Automatic Transmission, Manual Transmission
92-95 Honda Civic Si
93-95 Honda Civic VX, 2-Door, 3 Door, California Models Only, 4 Door, California Model
Anyone know what is different about these primary o2 sensors?
Is it the harness?
or something different about the voltage output to measure the o2 concentration in the exhaust?
And what is a GX?
Thanks in advance!
Old Feb 26, 2009 | 01:27 PM
brutekiller787's Avatar
Default Re: Wtf, is a 1998 Ex o2 sensor really different than a 1999 Ex O2 sensor?!?!?
99+ is obd2b
96-98 is obd2a
the plugs are in different locations in the ecu. it's minor but with an o2 sensor it makes a difference
Old Feb 26, 2009 | 01:52 PM
94EG8's Avatar
Seagull Management
Often its just the length of the harness on the O2 sensor itself, most OBD1 and OBD2 civic and Integra O2 sensors function the same way. Its only the single wire and 5 wire versions that are truly different.
And what is a GX?
6th gen civic sedan (available from '98 - '00 IIRC) that runs on CNG (Compressed Natural Gas) I believe they were only sold as fleet vehicles.
Old Feb 26, 2009 | 03:55 PM
Thanks guys for the prompt info!
So, should this work?
Originally Posted by brutekiller787
99+ is obd2b
96-98 is obd2a
Forgive me but, I'm not understanding how the location on the ecu has anything to do with the sensor itself. I am not changing where the harness plugs into the ecu, just the sensor. So the location on the ecu is the same. The ecu is getting input from the same harness and same location, it's just the sensor that's getting changed. Changing the sensor does not change the location my ecu gets it's o2 readings from.
I could see how this would be a problem if I would swapping ecu's, but I am not.
Old Feb 26, 2009 | 04:03 PM
94EG8's Avatar
Seagull Management
I make no guarentees, but I don't forsee a problem.
Old Mar 5, 2009 | 07:06 AM
Just got the 98 ex OEM denso replacement in the mail.
It is very different indeed from the 99 ex.
The 98 ex sensor has a longer pig tail and a male harness.
The 99 ex sensor has a female harness and is obviously shorter.
Also, the wire colors are different.
99ex OEM; green, white, and the two black heater wires
98 ex Denso; blue, white, and two black heater wires
grrrr........
eastbay92cx
Northern California (Sales)
Jan 2, 2019 10:03 AM
b16ajdmrex
May 7, 2013 05:55 AM
Project H
Mar 3, 2011 10:57 AM
