Rod bearings ; oem honda b18b vs acl?
Old Feb 26, 2009 | 10:32 AM
Pompiuses's Avatar
Default Rod bearings ; oem honda b18b vs acl?
I've got a GSR short block with a b18b 89mm crank. I've got a built head so I'm planning to rev it over 9000rpm or until the turbo run out of breath.
Should I use oem honda b18b bearings or should I go with acl?
I hear some people use b18c rod bearings even when using a b18b crank. Is that safe?
Old Feb 26, 2009 | 10:36 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Rod bearings ; oem honda b18b vs acl?
honda bearing are color matched. I personally would use OEM bearing but you will hear a lot of people say ACL race bearings. As long as the bearing are within specs your good but my preference is OEM
Old Feb 26, 2009 | 10:48 AM
SilverEk3dr's Avatar
OEM FTW. Just make sure the clearances are perfect, and dont try to be smarter than an engineer. Just use ls bearings w/ls rod or gsr w/gsr rods.
/thread
Old Feb 26, 2009 | 10:59 AM
mar778c's Avatar
Community Builder
Community Influencer
The rod has to be re-tanged. Also, you have to make sure the oil holes match up. (see thread link below)
https://honda-tech.com/forums/showth...2297543&page=2
Old Feb 26, 2009 | 11:46 AM
Pompiuses's Avatar
I've read that the oem b18c bearings comes with a coating that the b18b bearings doesn't have. Making the b18c bearings better for high revving motors.
Can anyone confirm that?
Old Feb 26, 2009 | 11:57 AM
mar778c's Avatar
Community Builder
B18C rod bearings are better because the tri-metal construction has a better lubricity. This allows the rod bearing to be more narrow than the b16a and b18b bearings.
Old Oct 12, 2009 | 05:18 AM
ZAWAIA's Avatar
I'm rebuilding my b16a2 block and I want to replace the bearings.
Could I use the b18c ones that you where talking about or they can only be use in b18c engines?
If using ACL do you prefer normal or race ones?
I will use Eagle H-Beam rods, do you know which color of oem bearings I need to use?
Thanks
Old Oct 12, 2009 | 07:52 AM
fmfkid250's Avatar
I run ACL Standards. There cheap. and seem to work well.
Old Oct 12, 2009 | 08:23 AM
Pompiuses's Avatar
Too bad the ACLs don't come in different clearances like the oem bearings does. Might not work on every motor.
Old Oct 13, 2009 | 06:39 AM
DA TeG 90's Avatar
I bought ACL Race Bearings for my next years bottem end build. Either or is fine.
Old Oct 13, 2009 | 06:54 AM
fmfkid250's Avatar
I have only seen one motor that wasent within spec!!
Old Oct 13, 2009 | 07:27 AM
ZAWAIA's Avatar
What do you guys recomend to use with eagle h-beam rods?
Old Oct 13, 2009 | 04:05 PM
Innes's Avatar
acl bearings are offered in various sizes
they have STD Size, .025 over, .25 Over, 1.00 over sizes in particular for the B18a/b Rod Bearings
those are for the race bearings
the basic bearings are offered in STD, .25 over, .50 over, .75 over and 1.00 over
we have been running the ACL Race Bearings in our racing engines with great success
Old Oct 13, 2009 | 04:11 PM
loudassVTEC's Avatar
B18b bearings are okay, but the GSR bearing is superior with it trimetal construction. Its also more narrow, and therefore has surface area, so it has less friction. Less friction=less heat, and slightly more power.
spoolinvtec54
Nov 13, 2011 09:06 AM
BukakkEK9
Apr 2, 2007 07:38 PM
GSRCRXsi
14
Jul 11, 2005 07:09 PM
mdixonjam
May 20, 2005 11:30 AM
totalimpact
Nov 11, 2003 06:39 PM
