mini me swap
i have a 88 crx si stock
im getting ready to do a mini me on it
ive read on here many things about it but i hear that this is better than that and so on
well my question is which head hasket is better to use on a z6 head
and what timing belt is best to use i had in mind to use the 95 civic ex belt since thats what my head is off of.
as far as wiring goes what all do i need to conect
im ganna either use a p28 or p30
i know a gatta conect the vtec and the 4 wire o2 and repin my stock dizzy plugs is there anything else i need to wire?
The reason why nobody responds is because all of your questions can be answered in the FAQ. Also if that does not satisfy you then you can use the SEARCH button. This has been covered numerous times on exactly what to do.
The only one that maybe you won't find is the head gasket question. The better head gasket to use is the Z6 it is .037" compared to the A6 which is .048", the Z6 will give you a little higher compression.
P.S. The Y8 head gasket is the same thickness as the Z6...
zapzach
May 7, 2013 09:39 AM
gotboosthatch
Feb 15, 2008 10:21 PM
PrestonCRX
Apr 9, 2006 02:54 PM
