NEED HELP! coolant leaking INSIDE my car
Old Aug 10, 2002 | 06:49 PM
civicb18b's Avatar
Default NEED HELP! coolant leaking INSIDE my car
Today I was istalling motor mount inserts. In the process of removing the rear mount, I drained my coolant. I also disconnected the coolant line going to the firewall. After putting my car back together, I started to pour coolant in the radiator. I noticed coolant was leaking near the hose that was connected to the firewall. My friend adjusted the clip, eventually fixing the drip problem.
Once in my car, I couldnt turn the heat all the way to HOT. I didn't think anyhing of it. I ran my heat for a 20 min drive. My car was running surprising cool. Then my car began to run REAL hot at a light. Basically overhating. I was also leaking coolant inside my car! I then drove home, which took 20 min, without the heat on. I set it the temperature thing to cold, and the air to recirculate, and when I got home I heard a hissing inside the car. Again, more fluid in the car.
HELP!
[Modified by civicb18b, 10:50 PM 8/10/2002]
Old Aug 10, 2002 | 06:58 PM
civicb18b's Avatar
Default Re: NEED HELP! coolant leaking INSIDE my car (civicb18b)
To make things worse, I have a 900 mile road trip to IL tuesday.
Old Aug 10, 2002 | 07:25 PM
Chiovnidca's Avatar
I hope you didn't screw up your heater core. Cross your fingers make sure your hoses are sealing properly.
Old Aug 10, 2002 | 07:32 PM
civicb18b's Avatar
Default Re: NEED HELP! coolant leaking INSIDE my car (Chiovnidca)
I am afraid it might be the heater core. Even if it is, can I bypass that coolant line? I noticed I'm not leaking coolant from the line I disconnected, rather, I juse hear hissing and see coolant INSIDE the ****** car!
I could give two ***** about my heat right now. I just want to make it to IL tuesday.
[Modified by civicb18b, 11:33 PM 8/10/2002]
Old Aug 10, 2002 | 07:34 PM
civicb18b's Avatar
The heat does work even though I can't adjust it to full on hot.
Also the metal fitting the coolant line goes over has been crimped slightly. I don't see how this would cause coolant to leak inside..
[Modified by civicb18b, 11:37 PM 8/10/2002]
Old Aug 10, 2002 | 07:39 PM
Chiovnidca's Avatar
Yea, you can bypass it.
Old Aug 11, 2002 | 05:18 AM
civicb18b's Avatar
anyone else?
klewis50
Jul 2, 2013 09:55 PM
BubLBack
Oct 5, 2006 09:47 PM
hondaracin24
May 11, 2006 08:56 PM
Cashis Lee
Apr 28, 2005 04:29 PM
dunkd
Nov 13, 2003 07:28 AM
