F/S Vitara Pistons, Custom Rods, SOHC Parts
Old Feb 25, 2009 | 11:49 PM
stevenmannn's Avatar
Default F/S Vitara Pistons, Custom Rods, SOHC Parts
YCP Vitara pistons (75mm)
-Wrist pins and C clips
-Piston rings (Hastings or NPR)
-Timing Belt
-Water Pump
-ACL Rod Bearings
-ACL Main Bearings
-ACL or King Thrust washers
-Full engine Gasket & Seals set-->
Its all the gaskets and seals you will need for your engine from
the oil pan and up to the head.
Metal 3 layer Head gasket (approx .030 thickness)
Custom length D16 Forged I beams connecting rods
5.458"C.C., .898" B.E.width, 1.89" B.E. bore, 1.771" Crank Pin,
0.7483" wrist pin (19mm) for floating wrist pins applications.
-For all Honda D16 engines using Vitara pistons
-For turbo applications.
-ARP 2000 Rod Bolts (3/8")
-ARP Lube
- 500+ whp rating
- Notching of Block required on D16 engines
$550 OBO For the pistons and rods.
D16 Block
with Main Girdle, Crank, Flywheel, Oil Pan, Intake Manifold, Throttle body, fuel rail, injectors
D16 Head stock
$700 for everything
Nothing assembled. This same set up on my friends D16 put down 416whp with 16lbs of boost on a gt35r
with head work and a cam, easy 500whp. Everything is brand new and still in packing besides the block. Decided to go another boosted route. Shipping will be at buyer's expense. Pictures will be up shortly, not lookin for trades thank you.
please email with any questions.
Steven_dc2@yahoo.com
Old Feb 27, 2009 | 02:09 PM
Default Re: F/S Vitara Pistons, Custom Rods, SOHC Parts
Old Mar 2, 2009 | 03:46 PM
j_kevin_ca's Avatar
are you willing to part the rods??
Old Mar 20, 2009 | 07:25 AM
setup is sold. thanks
Old Mar 20, 2009 | 11:56 AM
joker4096's Avatar
nevermind
Honda HP
Nov 8, 2010 07:23 AM
Keenor
Sep 22, 2010 07:55 PM
stevenmannn
Northwest (Sales)
Mar 12, 2009 03:18 PM
MikeD718
Aug 20, 2006 11:16 PM
