Steering wheel lock removal?
Old Feb 25, 2009 | 07:33 PM
1stgenboost's Avatar
Default Steering wheel lock removal?
im in the process of doing a new key and lock set and i need to remove my steering wheel lock for now. what is the best way to do so??
Old Feb 25, 2009 | 07:44 PM
allgo88's Avatar
Default Re: Steering wheel lock removal?
use a small dermal tool to cut slashes in the head.then you can use a flat head to get them out.
Old Feb 25, 2009 | 07:51 PM
isnt it just the metal band the wraps around the steering rod or am i looking at the wrong part?
Old Feb 25, 2009 | 08:20 PM
or does the metal band contain the locks inside of it?
Old Feb 25, 2009 | 09:24 PM
Canadian_EF's Avatar
I would assume... hang on, before i assume, i must get the trusty old Hanes manual out...
*runs out of sight*
*appears empty handed*
eff. someone took it.
well, i would assume that you would have to take off those headless bolts on it, and slide it off. the key cylinder has all the pins in it... and if you just cut the band, you gotta replace it. i have a steering column in my garage that I am gonna try and take apart tomorrow, i will let you know how it goes.
dustin_crxsi
Oct 30, 2006 05:29 PM
peel17
Dec 5, 2005 02:40 PM
ludedudeh23
Oct 29, 2004 04:33 AM
dingusjt
Jun 10, 2004 04:50 PM
Flamenco-T
Nov 19, 2002 07:32 PM
