Crank offset grind price
Just got the response from the shop. How does the price sound to you guys.
Hi,
The offset/grind labor is $150.00. May have to go to .25 under to get full 98mm stroke; depends on how good the original crank is. The balance labor is $125.00.
Ion nitride labor $150.00 + freight. (I do not do this in house; must ship to California to get it done.) Index grind & improved radius's on journals are all part of the deal.
Thanks, Mike
> I was wondering if i could get a price on a crankshaft offset grind. The crank is 4 cylinder honda crankshaft. Right now the crank has a 1.888 journal diameter and a 95mm stroke. I would like to go to a 1.771 journal diameter to up the stroke to a 98mm. Also I need to journals to be heatreated, micropolished, and balanced. Thank you for your time, Tyler
Hi,
Thanks, Mike
http://www.valleycrankshaft.com/ This is the company that I am talking to about it. Thanks DonF
Doesn't seem to include price for heattreatment.
Around the USA, I have seen pricing from $500 to $1500 for offset grinding..
It depends who is doing it and it helps if they have experience with honda cranks.
i have a complete setup for sale. Stroker 99mm crank, custom Arias 16.5:1 pistons, Custom aluminum rods, RS sleeved block 90mm bore. with brand new bearings. all brand new custom parts never used.. This block is unassembled with brand new parts.
i'll sell it for $2500 plus shipping.... it will cost you less to buy this setup than get a offset grinded crank... plus this is a complete custom setup. the pistons are coated and have lightweight buttons.. sick setup. just going with a different setup now so this is for sale..
Lmk if you are interested! PM me...
Do you still have the full set crank ,block ,rod and piston for sell,...I am looking for a b-series block with the min set as 98mm crank ,long rod ( more than 142mm ) ,& custom piston 86.25mm.do you no any one pls adv me...
Thank you
That was an H22 Block. I do have a B series Long rod motor but its a 89 crank GSR block. 87 bore.
Can you adv the spec ...
1.normal GSR block or Hight block ??
2.Rod type and lenght ?
3.What type piston and comperation...??
4.What crank & type ??
5.Current bore size and what is the max bore size.
Have you used this engine before ,if yes what is the dyno result...whp & tq..
What is the price ..????
Hi there,
Aluminum Rods (Howards Custom)
Pistons are Custom Ross Pistons (Max Dome)
LS 89 Crank
87 Bore RS Sleeved
I'll Take $1400 Shipped. Its a deal. All custom parts.
This block with a stock head, blox stage 2's, cheapy header, made 247 on a conservative dyno.
Car ran 11.59 full body street car 92 civic hatch.
PM me if ur interested.
i have a 95mm crank from scat pm me me if you want it
