what length header?
Old Feb 25, 2009 | 08:00 AM
turbo97coupe's Avatar
Default what length header?
delete i reposted thread in the TECH section i feel its more suited there thanks
Old Feb 25, 2009 | 09:27 AM
Default Re: what length header?
delete
Old Feb 25, 2009 | 10:08 AM
Combustion Contraption's Avatar
You waited an hour and a half. You may have to wait a bit longer for a good response.
Old Feb 25, 2009 | 10:29 AM
Mag00n's Avatar
Originally Posted by turbo97coupe
as the title says iam about to start my B20/vtec swap in my 98 civic sedan , and iam running a oem cat and oem exhaust and plan on running a oem header , which oem header do i need that will bolt directly to the factory cat with no mods needed to anything just a complete bolt on . iam trying to avoid shortening or lengthing anything if possiable ,iam guessing a B16 header like the 99-00 SI's but iam not sure if the height of a B20/vtec is different and if that would change anything TIA
b16 header fit my b18c5 just BARELY so if the b20 is much taller id say it wont
Old Feb 25, 2009 | 02:39 PM
delete
Old Feb 28, 2009 | 10:27 PM
delete
Old Mar 1, 2009 | 08:35 AM
project dc2's Avatar
a b18C vtec header will clear your motor. but i dont think theres any combo of exhaust and cat you can use that will not require welding/lengthening of your cat to bolt up 100%
Old Mar 1, 2009 | 08:37 AM
thanks man can somone delete this thread for me i moved it to the tech section i think it belngs there
90efhatch
16
Sep 14, 2011 12:36 AM
recon23
Jul 13, 2009 05:10 PM
chevellion
Jan 14, 2008 10:00 AM
BerlinaAP2
Apr 1, 2003 09:55 PM
tegrevboy
Dec 16, 2002 08:18 PM
