Blox A's and boost?
i was wondering if anyone has good results with the blox a's and boost ive got the average setup
lsvtec
ramhorn
60-1 stage 5 .82ar
victor x
3'' exhaust
shooting for around 450whp
and i need a set of cams...i sold the b16 cams and need a set...just wondering about the blox a's? any input
lsvtec
ramhorn
60-1 stage 5 .82ar
victor x
3'' exhaust
anyone have experences with how the A's and B's idle? do they have to be degreed in?
The B's idle just as good as stock cams, you should not be worrying about over camming your car. B's are not too big, make great power and idle great. And both i and my buddy have them set a -1 on intake side and +1 on exhaust seems to be the best settings for the cams throughout the extensive cam gear settings we tested on the dyno
anyone know what blox's are equal to which skunk cams?
because from what i've heard they are the same grinds or very similar
100 and 60 come to mind im just not sure what the right minimum amount needed is. if i were you i would pm or email jeff and ask him, as im sure he will steer you in the right way
but i do know for some of these big skunk and blox cams need more spring pressure than any of the stock cams or it can cause bad things to happen with something messing up in the valvetrain
do you know what spring pressure your springs are?
hope that helps
They do not have to be degreed in for them to run properly at idle. Mine were set at 0-0 for almost a month before i went on the dyno. And you need right arount a 160 spring pressure, which is the lowest of the b series spring rates that supertech sells. I personally have the highest one of 266 because im revving to over 10k and have them just for mere safety purposes. And they are identical to the skunk 2 tuner series stage 2's. Same lift on all lobes both exhaust and intake.
something don't add up between the 2 of you guys spring rates.
if the b's are equal to those skunk cams thats what i would go with because the skunk ones are badass they made like 50-70 whp over gsr cams
He was talking about seat pressure. I'm talking about the about of pressure it takes to compress the springs. Mine are rated at 266lbs.
B's are identical to tuner 2's from skunk.
Tuner type b's have an oem primary lobe ie. Type r, gsr etc. They also make a competition type b, has the same vtec lobe on both cams as the tuner b's but has bigger primary lobes. Helping with spool time and lower end power before vtec engages
I'm running blox type A's with boost. they work great idle like stock cams and pull nice in the top end. I'm sure the B's would get you more power but you may sacrifice idle quality? anyone know if the primary lobes between the A's and B's are the same/different?
anyway best dyno pull so far was 17psi 420whp @ 8500rpm and still climbing on my b20/vtec with a t3/t04b 57-trim.
The B's are fine. They are a excellent top end cam for boost and they idle the same as R's or Blox A's. If your tuner is any good he will dial out some of the overlap and get you even more power.
Take out some of the overlap??? Have you used The Blox B's before? In all my experiences and people i know that have run blox b's have added overlap. My cams are set a -1 exhaust and +1 intake.... I recently added a victor x and bigger .82ar housing and didnt adjust the gears, but the way its looking they need more overlap
