Blox A's and boost?
Old Feb 25, 2009 | 06:51 PM
  #26
boostedeg6-1's Avatar
Default Re: Blox A's and boost?
Thanks, that was on pump gas!
Old Feb 25, 2009 | 07:49 PM
  #27
redflaredcrx90's Avatar
are there any identfing marks to tell the cams a part
Old Feb 25, 2009 | 11:35 PM
  #28
project dc2's Avatar
on blox b'S IVE MADE 17 over ITR's on a 400WHP setup 81.5mm sleeved block with turbonetics 62-1 turbo
great cmas and right now they can be had for insane pricing
Old Feb 26, 2009 | 04:55 AM
  #29
mar778c's Avatar
Community Builder
Community Influencer
Originally Posted by boostedeg6-1
Take out some of the overlap??? Have you used The Blox B's before? In all my experiences and people i know that have run blox b's have added overlap. My cams are set a -1 exhaust and +1 intake.... I recently added a victor x and bigger .82ar housing and didnt adjust the gears, but the way its looking they need more overlap
Yes, I have used them and I stand by what I stated. I've seen them used on a handful of set-ups. The majority made more average power and torque by reducing overlap but do whatever produces the best results for you.
Old Feb 26, 2009 | 07:19 AM
  #30
turbo boost's Avatar
uggghh im undecided on what cam to choose on my setup the A's or B's
Old Feb 26, 2009 | 07:44 AM
  #31
You can come across the cams for deals right now, dont waste your money on something that is slightly bigger then itr cams. B's are really not big, they would not be over camming your setup by any means. They will forsure make 45+ more then the A's. you have a good setup to make power, so buy the cam that will support that.
Old Feb 26, 2009 | 07:59 AM
  #32
yes project dc2 has a smoking deal on blox cams...i just have to decide on with cams to choose...maybe i will get the B's uggghhh lol
Old Feb 26, 2009 | 08:01 AM
  #33
mar778c's Avatar
Community Builder
There's really not much to decide. Get the b's you make more power on less boost with the b's. I believe project dc2 is selling Blox a, b, and c cams for $350 a set.
  #34
mar778c's Avatar
Community Builder
Most definitely.
Old Feb 26, 2009 | 09:43 AM
  #35
JFK78's Avatar
boostedeg6-1 is mistaken. He stated his cam gear settings correctly the 1st time at the top of this thread.
They do have overlap dialed out... intake -1, exhaust +1.
Old Feb 26, 2009 | 11:36 AM
  #36
maybe ill go for the B's then..it looks like people have good experince with them
Old Feb 27, 2009 | 06:52 AM
  #37
They do not have to be degreed in for them to run properly at idle. Mine were set at 0-0 for almost a month before i went on the dyno. And you need right arount a 160 spring pressure, which is the lowest of the b series spring rates that supertech sells. I personally have the highest one of 266 because im revving to over 10k and have them just for mere safety purposes. And they are identical to the skunk 2 tuner series stage 2's. Same lift on all lobes both exhaust and intake.
another question is..i see you said you have the stiffer of the supertech springs,same as me...how is valvetrain wear with the B's? any rocker arm wear noticed?
Old Feb 27, 2009 | 09:47 AM
  #38
just ordered a set of Blox B's from project dc2...great price $350
cant wait to get them in and try'em out
Old Feb 27, 2009 | 05:04 PM
  #39
jfoster's Avatar
If I have a B16 head with ITR valves/springs/retainers I could probably run A's but the B's would require stiffer springs correct?
Old Feb 27, 2009 | 06:30 PM
  #40
92redhatch's Avatar
I RUN BLOX A'S on my 84x89 setup on a turbonetics 62-1 they idle like stock.
ty91184
Oct 22, 2008 05:55 PM
zex_cool
Jun 6, 2008 10:10 PM
hellakapps
Oct 18, 2007 01:05 PM
dbiker207
Jun 16, 2007 02:52 PM
nos51
Oct 10, 2005 10:07 AM
