Stupid 4 door!
Old Feb 25, 2009 | 12:40 AM
Clipsed's Avatar
Default Stupid 4 door!
**** is being gay, so pissed off, I pulled off my gas tank to put a new strainer on the pump, now it's doing this...
Old Feb 25, 2009 | 11:53 AM
h224thgensedan's Avatar
Default Re: Stupid 4 door!
Is it starving for fuel?
Old Feb 25, 2009 | 01:01 PM
savage 91 si's Avatar
did you change the fuel filter?
Old Feb 25, 2009 | 01:08 PM
MyHotsh's Avatar
Verbal abuse on Ef's will NOT be tolerated!!! lol!
Your filter might of got clogged. Try replacing it or recheck your previous work..(the strainer on fuel pump)
G/L
Old Feb 25, 2009 | 01:12 PM
Clipsed's Avatar
It's weird though, because the fuel filter is brand new, I haven't even driven it maybe but 1000 miles IF THAT on the new fuel filter...
The car was running completely fine until my crank pulley bolt came off on the freeway, then it started acting weird, and would bog out at throttle. Other than that, ZERO PROBLEMS. That was why I was thinking maybe the strainer was clogged since the filter was new, but the problem now seems worse.
Old Feb 25, 2009 | 03:06 PM
Clipsed's Avatar
anyone else?
Old Feb 25, 2009 | 03:11 PM
jdmed3's Avatar
Its hard to tell but maybe check your vacuum lines
Old Feb 25, 2009 | 03:22 PM
redef90si's Avatar
main relay?maybe check fuel pressure regulator?GL man
Old Feb 25, 2009 | 04:02 PM
How long did you drive with the crank pulley off?
Old Feb 25, 2009 | 06:07 PM
Clipsed's Avatar
I have new lines on most of the Vac hoses, but I will double check it.
I have swapped the main relay to a known good one, I do need to check my fuel pressure, but I do not have the tool to do so, but will get it asap.
not very long but the pulley didn't fall off, it stayed in place, only the key and bolt came off, but I don't understand why it would cause this problem? Like I said, car was running fine and STRONG prior.
Also the Map sensor was good, but who knows, could have went bad after the whole crank pulley thing, because I know my Dizzy went bad at that time, and I had to swap it.
I appreciate ANY and ALL help you guys can give me, because I have been screwing around with just about everything.
Old Feb 25, 2009 | 06:53 PM
CRX30436's Avatar
this might me kinda dumb to say but did you make sure there was enough gas in the tank bc when i replaced the strainer in my crx it was doin the same thing and i did all kinds of dumb **** as well thinking it was some thing worse untill i put gas in the tank.
if you do have enough gas go back and check the strainer and the fuel pump. the strainer might have fallen in the tank during installation or one of the wires might have come loose or busted at the fuel pump.
thats all i can think of.
hope it helps carnal!!
Old Feb 25, 2009 | 07:12 PM
~sp33~'s Avatar
EFB055
When the car starts does it sound like it's bogging?
Old Feb 25, 2009 | 11:32 PM
Clipsed's Avatar
I put around 4 gallons of gas in that bitch, I would hope that is enough! The strainer has something (the hell if I remember if it's a screw of what) but I would think it would still be on there. I will have to try ANYTHING and EVERYTHING.
somewhat, sounds more like it's running on some rougher cams, but sometimes it sounds normal, if I gas it, it sounds boggy.
Old Feb 26, 2009 | 07:57 AM
4drEF's Avatar
Keyboard Humorist
Did you change out the fuel filter after messing with the fuel pump?
Could have broke some debris off and it made it's way to the filter.
Old Feb 26, 2009 | 09:27 AM
Singlecam4dr's Avatar
i was going to say that^^ otherwise maybe its in the injectors, pcv valve or as stated fuel pressure. hope you figure out whatever it is GL!!
Old Mar 3, 2009 | 10:48 PM
Clipsed's Avatar
negative, fuel fiter was changed before awhile back.
it's become very annoying.
Old Mar 4, 2009 | 04:18 AM
daoshao's Avatar
That right there could be your problem. Timing could be off or maybe you didn't luck out and got damaged valves.
Old Mar 4, 2009 | 03:12 PM
Clipsed's Avatar
Timing is NOT off, I have checked it NUMEROUS times, and it's dead on. If it were damaged valves though, why would it start up, and then shut off after running?
Old Mar 4, 2009 | 03:21 PM
mitsubishiv5's Avatar
it wouldnt hurt to check the valves
Old Mar 4, 2009 | 03:31 PM
4drEF's Avatar
Keyboard Humorist
so filter was AFTER you did the pump.
might have plugged up with debris.
Also, the sock on the pump might be sucking up into the pump.
I remember hearing people with that rare problem long time ago.
Car would run and shut off a bit later after it finally got starved for fuel.
Do you have a fuel pressure gauge? Maybe monitor that for the short while that the car runs. See if it the pressure drops as the engine runs and finally dies.
What happens if you start is and try to hold the RPM at about 2,500?
Does it die or will it stay on?
I listened to the video a little more closely and it almost sounds like it only dies when at low RPM.
Old Mar 4, 2009 | 04:06 PM
uberEFtuner's Avatar
Just a shot in the dark but my civic did this same thing when I left it in storage and a mouse chewed through some wires. You might want to check your wiring in the dark with a bright flashlight. That how I found out about my rodent attack.
crappyshifting
Apr 5, 2011 07:44 AM
skidrow2k4
Honda Civic (2001 - 2005)
Oct 8, 2007 08:03 AM
IMSTOCK
Jun 21, 2005 06:42 PM
civic_slut
11
Jul 28, 2004 07:08 PM
