Brake piston adjusting
Old Aug 10, 2002 | 03:31 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Brake piston adjusting
I need to move my right front brake piston in about 1.2mm to clear enough room for my new brake pads. Whats the quickest way to do this?
Old Aug 10, 2002 | 03:47 PM
champITR's Avatar
From: If ignorance is bliss... I am in the happiest, place on earth.
Default Re: Brake piston adjusting (Rguy)
you mean compress it?? I usually use a huge c-clamp, but I have seen it down with channel locks (I just don't like how it mares up the piston surface.)
later
matt
Reid's Avatar
Global Moderator
C clamp.
Old Aug 10, 2002 | 04:28 PM
Back in Black's Avatar
Rather OG
Get a "brake piston clamp" from Sears. They're only about $5, and blow c-clamps out of the water
Old Aug 10, 2002 | 04:45 PM
TypeR 599's Avatar
Default Re: Brake piston adjusting (Jason Franza)
usually people have clamps around, so since they already have it, why waste another 5 bucks. dont forget to do it slowly
Old Aug 10, 2002 | 04:49 PM
Rather OG
Default Re: Brake piston adjusting (TypeR 599)
Um...because it's easier.
Jason-
who thinks people that argue with opinions are funny
Old Aug 10, 2002 | 04:50 PM
Reid's Avatar
Global Moderator
Well when you change brake pads after every couple of times you take it on the track, you might as well get the right tools for the job.
But you're correct, most ITR owners never see track time, so why bother getting the right tool for the job.
Old Aug 10, 2002 | 06:04 PM
Rguy's Avatar
25 Year Member
Community Builder
Default Re: Brake piston adjusting (Reid)
Appreciate it guys, ill go get that ASAP.
Rguy, who realizes sears is closed at 10 oclock at night...damn.
Old Aug 10, 2002 | 06:30 PM
Flux's Avatar
Craftsman Disc Brake Pad Spreader
For installing pads on most domestic and import cars and light trucks. Makes changing pads an easy job. Tool compresses brake piston for easy pad installation.
$9.99
Sears Item #00947365000
Old Aug 10, 2002 | 06:33 PM
Rob :190:'s Avatar
Default Re: Brake piston adjusting (Flux)
[zoolander]coool[/zoolander]
Old Aug 10, 2002 | 08:23 PM
Rguy's Avatar
25 Year Member
Community Builder
Default Re: Brake piston adjusting ( Rob)
flux, ur the man.
Old Aug 10, 2002 | 09:12 PM
01PYITR's Avatar
and I've been using a very long snap-on screw driver for years...
hodsintegra23
Apr 6, 2022 11:12 AM
szczerbanator
May 26, 2009 05:06 PM
leviq
Jul 7, 2007 08:28 AM
beseman
Dec 30, 2003 08:10 AM
