cel code
Old Feb 24, 2009 | 06:58 PM
aggressivecivic's Avatar
Default cel code
anybody have any ideas on what else to check to get rid of a P0171 code? its a 2000 civic si with a b20 vtec motor. i replaced the fuel pump because it went out, and i have replaced the primary o2 sensor also. any help would be appreciated. thanx
Old Mar 9, 2009 | 08:24 AM
Default Re: cel code
anybody had this problem? i really need help trying to get this figured out. thanx
Old Mar 9, 2009 | 08:41 AM
mouab18c1's Avatar
P0171 Fuel System Too Lean. What ecu are you running? you are starving your motor
Old Mar 11, 2009 | 05:58 PM
its the stock ecu and it only has intake. no other mods.
Old Mar 11, 2009 | 08:26 PM
baggedSIcivic99's Avatar
i have a 97 civic its coding 65 what would that be my motor is a d16y7
Old Mar 12, 2009 | 06:51 AM
mouab18c1's Avatar
stock what? SI? b20? if its an SI then thats your problem since b20 needs more fuel..Get an ecu chipped to a 2.0 liter for your setup and get it tuned
Old Mar 12, 2009 | 07:18 AM
talampunay's Avatar
1.) look for vacuum leaks
2.) possible clogged up fuel filter
3.) bad fuel pressure regulator
4.) good luck
hatchet_honda
Jul 26, 2010 08:54 PM
si90rex
Feb 14, 2010 11:59 AM
MX500
Oct 26, 2008 01:51 PM
92integraVTECgsr
May 15, 2008 06:55 AM
DB8B20asic
Oct 20, 2004 07:45 PM
