Drivetrain problems.. need help ASAP
Old Aug 10, 2002 | 02:56 PM
[626]95-GSR's Avatar
Default Drivetrain problems.. need help ASAP
I have a d16a6 with an HF tranny (dont ask why)... Recently ive been having major problems putting my car into gear.. I push the clutch ALL the way down, try to put it in First.. and it goes in with A LOT of resistance. I have to FORCE it into gear.. and when i do finally get it into gear... the car shudders, as if the clutch is engaged. Second gear, I have to force it in also. Third gear goes is with a HUGE grind.. putting the car in Reverse come with a huge, nasty grind as well. The clutch grabs HARD, its a 6 puck dual diagphram action clutch. I tried to adjust the clutch cable a little, but the problem always comes back.. ive actually adjusted it all the way, now theres no more cable left.. what is the problem?!
Old Aug 11, 2002 | 12:13 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Drivetrain problems.. need help ASAP ([626]Rj-SiHatchy)
stretched clutch cable from too big of a pressure plate,
replace your clutch cable about every 15,000 miles now.
Now why did you need such a manly clutch?
Might wanna check the wear on the thrust bearings on the crank sometime also.
[Modified by Mista Bone, 4:14 AM 8/11/2002]
Old Aug 11, 2002 | 08:51 AM
deepnite's Avatar
Default Re: Drivetrain problems.. need help ASAP (Mista Bone)
u have any gear oil in there?
hotsuma23
Sep 7, 2008 08:16 PM
trianglegreg
Nov 12, 2005 10:58 AM
Luserkid
16
Nov 13, 2004 08:57 PM
[626]95-GSR
Aug 11, 2002 12:24 AM
senpai
Apr 30, 2002 01:15 PM
