If fuel primes, coil is good, but still no spark..
could it be the ICM in the dizzy? the ICM needs spark to work, right?
if the fuel primes (pump + main relay good), the coil is good, but i still dont get spark, is it safe to say a whole new dizzy will fix the problem??
or could it be something else?? halp!
More than likley yes you will need a new dizzy.
Your fuel pump runs to pressure and kicks off Main relay is good.
You say the coil is good, ill take your word on it.
Their will be no signal to spark if you Cam shaft position sensor has gone bad in the dizzy. Which means you need to replace the dizzy. The CKPS is non serviceable so it requires a new dizzy
ya change icm.mine did the same thing.i think its only like 50 bux at an autozone and it has lifetime warranty.i hear they go bad often.
panda teggy
11
Jul 6, 2011 01:18 PM
NL826
15
Jan 23, 2010 12:22 PM
